NTIB-99309 keM Application Note Fat and Oil Peroxide value of Oleic acidRedox titration byAutomatic Potentiometric TitratorTest Method for Analysis of BasicFSatty MaterialtandardISO 3960 1.Abstract The oleic acid is widely distributed in plant and animal fats. Measurement ofperoxide value (POV) of oleic acid is demonstrated in this application according to thebelow quoted test method. The test sample is first dissolved in mixture of chloroformand acetic acid(2:3). By flowing nitrogen gas through the sample to dispel residualoxygen, add potassium iodide, and then titrate free iodine with 0.01mol/L sodiumthiosulfate. The endpoint is determined by the maximum inflexion point on titration curve.POV is calculated from titration volume of sodium thiosulfate. I2+2Na2S2O:l→ Na2S406+2NaI 2. Reference 1)'Test Method for Analysis of Basic Fatty Material by Japanese Oil ChemistrySociety; Reference material 2.4-1996 Peroxide value (Chloroform Method) 2)ISO 3960 : 2007 Animal and vegetable fats and oils -Determination of peroxidevalue B. Cautions in measurement 1)Do not use water containing carbon dioxide in preparing saturated potassiumiodide solution. 2)To confirm saturation, add excessive potassium iodide to the saturatedpotassium iodide solution, and leave crystal in the solution. 3Prepare fresh saturated potassium iodide each time. If the sample does not change color to yellow due to free iodine when saturatedpotassium iodide is added, add more saturated potassium iodide except whenblank test is performed or if peroxide value is very small in number. 5)Before potassium iodide is added, flow nitrogen gas through the sample to dispelresidual oxygen. 6)If potential change around EP is small, adjust Gain of Control parameter. 上海市漕溪路222号航天大厦北楼902室 4. Post-measurement care Rinse the electrode with pure water, and keep it dipped in water to avoid drying up. 5. Test equipment Main unit:Automatic potentiometric titrator (Standard preamplifier: STD-) Electrode Option Combination Pt. electrode 6.Reagent Reagent 0.01mol/L Sodium thiosulfate (f=1.006) Solvent Mixture of chloroform and acetic acid (2:3) Additive Saturated potassium iodide Inactive gas :Nitrogen gas 7. Measurement procedure -measurement- Deliver approx. 5g sample into a conical flask with stopper.24 Add 30mL solvent and gently shake to dissolve the sample completely. Gently replace the air inside flask with nitrogen to remove remaining oxygen. By further flowing nitrogen gas, add 0.5mL saturated potassium iodide, andimmediately seal the flask and gently shake it for one minute. 5Leave the flask at room temperature (15 to 20°C) in a dark room. Add 30mL pure water, and seal it and stir. Titrate with 0.01mol/L sodium thiosulfate to measure peroxide value.※Likewise, obtain blank level in advance by a blank test. 8. Formula Peroxide value (meq /kg)=(EP1 - BL1)×TF×R/ SIZE EP1 Titration volume(mL) BL1 Blank level (0.00mL) TF Factor of reagent(1.006) R Constant (10) SIZE Sample size (g) 京都电子工业株式会社-可睦电子(上海)商贸有限公司 上海市漕溪路222号航天大厦北楼902室 9.Example of measurement -Ambient condition二 Room temperature:22.5℃ Humidity: 47 % Weather:: Cloudy -Titration parameter- Titration curve- Model :AT-510Method No.: 11Titr.mode: AutoIntermit Titr.form:: EP Stop [Titration parameter] Form : EP Stop APB No. :1 :1 Unit No. : 1Detector No.Unit :mVMax.Volume :10.0mL Wait Time :0s Direction :Auto [Control parameter End Point No. : 1 End sense : AutoEnd Point Area : OffSeparation :(OffOver Titr.Vol. : 0mLGain :110Data samp.Pot.: 4.0mVData samp.Vol.:0.1mLStability 0.5mV/s Delay Time : 1s Limit Time :Os [Result parameter
还剩2页未读,是否继续阅读?
德国林赛斯热分析为您提供《动植物油脂中过氧化值检测方案(同步热分析仪)》,该方案主要用于食用动物油脂中理化分析检测,参考标准《暂无》,《动植物油脂中过氧化值检测方案(同步热分析仪)》用到的仪器有德国林赛斯 同步热分析仪 STA PT1600 。
