Journal ofFISHBIOLOGYfsbiAn International Societyfor Fish BiologyJournal of Fish Biology (2016) 89,753-769doi:10.1111/jfb.13003, available online at wileyonlinelibrary.com 754A. ASCHENBRENNER ET AL. Spatial and temporal variability in the otolith chemistry ofthe Brazilian snapper Lutjanus alexandrei from estuarineand coastal environments A. ASCHENBRENNER*+, B. P. FERREIRA* AND J. R. RoOKER$ *Universidade Federal de Pernambuco, Departamento de Oceanografia, Recife 50740-550,Brazil and +Department of Marine Biology, Texas A&M University, Texas Clipper Road,Galveston, TX 77554, U.S.A. Otolith chemistry of juvenile and adult individuals of the Brazilian snapper Lutjanus alexandrei wasmeasured to assess the utility of natural markers for investigating individual movements. Individualswere collected over a 3-year period (2010-2012) along the north-eastern coast of Brazil from bothestuarine (juvenile to sub-adult stages) and coastal (sub-adult to adult stages) areas. Six elements (Li,24Mg, 55Mn, 59Co, 88 Sr and 137Ba) were measured in sectioned otoliths of L. alexandrei using laserablation inductively coupled plasma mass spectrometry (LA-ICPMS). Edge composition analysis indi-cated that element:Ca ratios in the otoliths of juvenile and sub-adult L. alexandrei from estuaries werenot significantly different among the three consecutive years (2010, 2011 and 2012), suggesting thatphysicochemical conditions within the nursery area investigated were temporally stable. Similarly,apart from two elements (Ba and Co), element:Ca ratios for larger L. alexandrei inhabiting coastalwaters were also similar. In contrast, otolith chemistry of similar sized L. alexandrei from estuarineand coastal areas was significantly different (based on recently accreted material).Otolith Mn:Ca andBa:Ca were both significantly higher for L. alexandrei collected in estuaries compared to fish fromadjacent coastal reefs, while the opposite trend was observed for Sr:Ca. Given the pronounced differ-ences in otolith chemistry between estuarine and coastal areas, element:Ca transects were constructedfrom the core to margin of the otoliths for adults (age 7+ years) collected on reefs to determine thetiming of movement (ontogenetic migration) from estuarine to coastal areas. Based on observed pat-terns of decline for both Mn:Ca and Ba:Ca, it appears that L. alexandrei begin the move to more coastalhabitats (i.e. lower element:Ca ratios) after age 2 years. The patterns observed for this species highlightthe importance of conserving connectivity between coastal habitats to maintain sustainable fish stocksexploited by artisanal fisheries. C 2016 The Fisheries Society of the British Isles Key words: connectivity; movement between estuarine and coastal habitats; natural markers; ontogeny. INTRODUCTION Otoliths can serve as natural tags in fishes due to their acellular and metabolically inertstructure which can permanently retain elements that are accreted onto a growing sur-face (Campana,1999). Among the six most common elements routinely used in otolithmichemistry studies in fishes (Li,Mg, Mn, Cu, Zn, Sr and Ba) (Sturrock et al., 2012)the last two (Sr and Ba) have been widely used and accepted as useful markers ofenvironmental conditions in both estuarine and marine systems, as both reflectenvironmental conditions and are associated with salinity and temperature (Walther tAuthor to whom correspondence should be addressed: Tel.: +55 8197612989;email: brenner.ale@ gmail.com & Thorrold, 2006; Elsdon et al., 2008). Other elements seem to be regulated byphysiological conditions (e.g. Mg and Cu) (Sturrock et al., 2012;Woodcock et al.,2012) or more recently as a viable hypoxia/redox condition markers as seems to bethe case for Mn (Limburg et al., 2015). Analyses of either whole otoliths or smallareas within the otolith have been used to distinguish stocks or sub-populations andretrospectively determine migratory histories (Rooker et al., 2008, 2010) includingmovement between estuarine and marine waters (Thorrold et al., 1997; Secor et al.,2001; Gillanders, 2005). Despite their promise for describing movement and pop-ulation connectivity, the use of otolith chemistry is challenging due to the fact thatthese chemical tags are species specific and vary spatially and temporally within anenvironment (Gillanders, 2005). The use of multiple habitats during early life stages is a key ecological feature ofmany reef fishes (e.g. snappers, Sheaves, 1995 and groupers, Nakamura et al., 2008).Adults inhabit the marine environment and, after spawning, larvae and juveniles moveinto shallow coastal areas and estuaries, where they spend the first months or yearsof life (Gillanders, 2002a; Jones et al., 2010; Reis-Santos et al., 2012). Increased foodavailability and refuge from predators are benefits often associated with inshore or estu-arine habitats (Miller et al., 1985; Gibson, 1994; Mateo et al., 2010). Key informationfor managing fish stocks and designing marine protected areas relies on understandingontogenetic movements of different life-history stages as well as the timing of suchmovements, particularly the transition from juvenile to adult populations (Sheaves,1995; Gillanders,2002a,2005). Movement between estuarine and coastal habitats has been described for severalspecies of dominant taxa on reefs, including snappers (family Lutjanidae) in the west-ern Atlantic Ocean (Nagelkerken et al., 2000; Chittaro et al., 2006; Moura et al., 2011).One of the most common lutjanids on reefs in the south-western Atlantic Ocean is theendemic, and recently described Brazilian snapper Lutjanus alexandrei Moura & Lin-deman 2007. Similar to congeners in the Caribbean Sea, this species resides in estuarineor nearshore nurseries before moving to coastal reefenvironments later in life (Aschen-brenner & Ferreira, 2015). Despite its ecological and economic importance, basic lifehistory information for L. alexandrei is scarce (Fernandes et al., 2012; Aschenbrenner& Ferreira,2015). The aim of the current study was to evaluate the effectiveness of using natural chem-ical tags in otoliths of L. alexandrei for improving understanding of habitat use andassociated ontogenetic shifts for this endemic yet poorly understood snapper. Specificobjectives of this study were first, to assess spatial and temporal variability in the otolithchemistry (element:Ca ratios) of L. alexandrei from estuarine and coastal habitats todetermine the potential value of the approach. Next, element: Ca life-history transects(from the core to margin of the otolith) were used to determine the timing of movement(ontogenetic migration) from estuarine to coastal areas. MATERIAL AND METHODS SAMPLE COLLECTIONS Juvenile L. alexandrei were sampled at two sites, Formoso and Ariquinda Rivers,located in the Formoso River basin. Sampless were collected1 f1rom traditional corralfisheries landings operating over estuarine margins and parallel to mangrove prop roots.Specimens were collected during three consecutive years (2010, 2011 and 2012) in the dry FIG. 1. Location of collection sites of adult Lutjanus alexandrei (●, sites where fish were collected): (a) estuarinearea: Formoso River basin (FR) and (b) coastal areas Itamaraca (IT), Olinda (OL), Barra de Sirinhaem(SI),Barra de Santo Antonio (SA) and Barra de Sao Miguel (SM). ■, reefs;■, sandbanks. season (from November to April). As the collection sites were both at the mid part of theestuarine system and located <2 km apart [Fig. 1(a)], samples were considered as from thesame source and pooled for analyses. Additionally salinity and temperature were measuredon a monthly basis at each fishing site on board fishing boats during 2012. Adult individualswere either collected by commercial fisheries landings using gillnets or fish traps operatingover the continental shelf in depths between 30 to 60 m. Fish were collected at two sitesin the coastal portion of Pernambuco State: Itamaraca (IT) and Olinda (OL) consideredas the northern location, another two sites Santo Antonio (SA) and Sao Miguel (SM) inthe coastal part of Alagoas State, considered as southern locations [Fig. 1(b)]. Distancesbetween southern sites were <30km and distances between northern sites were <50km.Northern and southern locations were <230 km apart. All coastal individuals were collected in2012. In order to evaluate temporal variability in otolith chemistry within the estuarine area, 10juvenile individuals of L. alexandrei were randomly selected from each of the three consecutiveyears (2010,2011 and2012).Fish ranged in total length (Lr) from 16 to 17 cm. Spatial variabilitypatterns of otolith chemistry in coastal areas was estimated using 10 adult individuals randomlyselected from each site from north and south areas (n=40 in total) ranging from 28 to 29 cmLr. Differences in element:Ca ratios between habitats, estuary and the adjacent coastal site werealso tested using 10 individuals each from the Formoso River basin and the nearest coastal sitefrom the estuary Barra de Sirinhaem (n=20 in total). All samples were collected in the sameyear (2011) during the dry season. Samples ranged in L from 20 to 24 cm, comprising the largerindividuals from estuarine and smallest from coastal areas, though there was some size overlapbetween the two habitat types. Trace element life-history transects were then performed from ages 1 to 7 years in order toidentify possible migration patterns from estuarine to coastal habitats. Ten individuals of age TABLE I. Overview of type of analyses, sampling habitats, sites, sampling code, sampling year,number of samples analysed (n) and total length (Ly) ranges of Lutjanus alexandrei Type of analysis Habitat Sampling site Sampling code Year n L (cm) Temporal variability Estuarine Formoso river FR 2010-2012 30 16-17 basin Spatial variability Coastal Itamaraca IT 2012 10 28-29 Spatial variability Coastal Olinda OL 2012 10 28-29 Spatial variability Coastal Barra de Santo SA 2012 10 28-29 Spatial variability Coastal AntOnio Barra de Sao SM 2012 10 28-29 Miguel Habitat signatures Estuarine Formoso river FR 2011 10 20-22 basin Habitat signatures Coastal Barra de SI 2011 10 22-24 Sirinhaem Life transect Coastal Itamaraca IT 2012 4 26-28 Life transect Coastal Barra de Santo SA 2012 3 26-28 Life transect Coastal Antonio Barra de Sao SM 2012 3 26-28 Miguel FR, Formoso River basin; IT, Itamaraca; OL, Olinda; SA, Santo Antonio; SI, Sirinhaem; SM, Sao Miguel. 7 years, between 26 and 28 cm L, were randomly selected from all coastal areas. A summaryofdata collections is provided in TableI. Individuals collected from artisanal fishery landings in the estuarine and coastal areas wereplaced into labelled plastic bags, stored on ice and processed within 24 h. Both sagittae wereremoved using plastic forceps, rinsed with distilled water and cleaned of adhering tissue. Otolithswere then air dried and stored in plastic vials. A single otolith (right) were used for trace ele-ment analysis, as age had previously been determined in otolith (left) sections and used forage determination for stock assessment work [for details on age determination see Aschenbren-ner & Ferreira (2015)]. Measurements for annuli distances were performed for ages 1-7 years(n=170) parallel to the sulcus acusticus from the nucleus to the proximal face using a stere-omicroscope with reflected light on a black background (Fig. 2). Otolith images were captured,treated and measurements for the first seven annuli performed using the IMAGE Pro Plus V. 4.5computer programme (SPSS Science; www-01.ibm.com). OTOLITH PREPARATIONAND ANALYSIS One otolith from each fish was selected and prepared for chemical analysis. Each otolithwas first embedded in epoxy resin and a transverse thin section (1.5 mm) was removed fromthe core region using a IsoMet low-speed saw (Buehler; www.buehler.com). Each otolithsection was glued to a glass slide with crystal bond thermoplastic cement and thin sectionswere hand polished to the core on one side using 1200 grit wet-dry sandpaper and 3 umaluminium oxide lapping film rinsed with Milli-Q water. Polished sections were triple rinsedin Milli-Q water and air dried for 12 h under a laminar flow hood before being stored in aslide box. Trace element chemistry of thin sections was determined using a laser ablation inductivelycoupled plasma mass spectrometer (LA-ICPMS) at Texas A&M University at Galveston. Thesystem consists of an ultraviolet laser ablation with a high-resolution digital camera (NWR 213,New Wave Research; www.esi.com) and quadrupole inductively coupled plasma mass spec-trometer with a Xs cone (ICPMS, XSeries II, Thermo Scientific; www.thermoscientific.com).Ablation diameters for points sampled on each otolith were 50 pm, and the location of annuli FIG. 2. Sectioned otolith of (a) Lutjanus alexandrei, scale bar=0.5 mm. Details of sectioned otolith (b) showingmeasurements performed in parallel to the sulcus acusticus from the nucleus to the proximal face of a8-year-old individual, scale bar=0.4mm was determined using otolith microstructure analysis. For assessments of spatial and temporalvariability, replicate points were ablated on the edge of each otolith to ensure that the anal-ysed material was recently accreted or from the capture location. Life-history transects wereperformed by ablating multiple points at each annulus from ages 1 to 7years. All elementalconcentrations were based on an average of four ablations on the otolith edges and an averageof three ablations for each annulus on the life-history transects. Before acquiring data, otolithswere pre-ablated using two laser pulses to remove any surface contamination. Six elementswere measured using LA-ICPMS: Li, 24Mg,55Mn,59Co, 88Sr and 137Ba. NIST 614 (NationalInstitute of Standards and Technology; www.nist.gov) was used as the external standard for cal-ibration. Calcium 44Ca was used as the internal standard to correct variations in ablation yield.Calcium concentration was assumed to be evenly distributed across the otolith sections at 38%or 388 000 pgg-, a published value for certified reference material of otoliths (Yoshinaga et al.,2000). For an ablated point size of 50 um, estimated detection limits (in pgg) for examinedelements were estimated as the quantity of analyte required to produce a signal equivalent tothree times s.D. of the NIST 614 (n=30), and were: Li: O·48,24Mg: 2-08,55Mn:0·33,59Co:0·25, 0.52, 88Sr: 3·71 and 137Ba:1·24. A calibration curve was generated for each otolith sam-ple and one standard run (NIST 614) was added every 10 ablations in each queue to monitorand correct the potential instrumental drift. After elemental analysis on the LA-ICMPS, otolithsections were examined under a microscope and a digital image of the ablated section was takenusing IMAGE Pro Plus V. 4.5 computer program (SPSS Inc., 1999) to confirm the laser ablationlocations (Fig.3). DATA ANALYSIS Element:Ca ratios (Li:Ca; Mg:Ca; Mn:Ca; Co:Ca; Sr:Ca and Ba:Ca) were first examined forwithin-group normality (Kolmogorov-Smirnov test) and for homogeneity of variances amonggroups (Levene’s test). When both assumptions were met, multivariate analysis of variance(MANOVA) was used to test for spatial and temporal differences in element:Ca ratios. Pillai’strace (V) was chosen as the test statistic because it is the most conservative test in MANOVA FiG. 3. Images of Lutjanus alexandrei otolith sections showing the laser ablation points for (a) edge analysis and(b) life-history transects of 7-year-old individuals for chemical analysis using laser ablation inductivelycoupled plasma mass spectrometry (LA-ICPMS). (Wilkinson et al., 1996). ANOVA based on ablation means and post hoc comparisons usingTukey’'s honestly significant difference (HSD) test were subsequently applied to detect any sig-nificant differences in element:Ca ratios among factor levels (i.e. years, coastal locations andhabitats). For edge composition analyses the following hypothesis were tested that: (1) therewas no variation in trace elements composition among the 3 years of collection for the estuar-ine area, (2) there were no differences in mean element concentrations among coastal locationsand (3) there were no differences between estuarine and adjacent coastal areas in otolith ele-ment concentrations. Once concentrations of element:Ca were detected to be relatively similaramong coastal locations and variation for estuarine and adjacent coastal area were observed forthree elements, elemental profile was tested according to the last hypothesis: (4) there was novariation in trace elements profiles across individual otoliths (i.e. from core to age 7years). The elemental profile of three elements that previously displayed significant differencesbetween estuarine and coastal areas (Mn, Ba and Sr) were matched to fish age based onaverage annuli measurements (1-7) in the otolith macrostructure as temporal references.Comparisons of elemental profiles across otoliths were made with repeated measures ANOVA.As Mauchly’s test for sphericity was violated for all three elements, the Huynh and Feldt correction computed in SPSS, was used to adjust F-critical values to protect against inflatedtype I errors in repeated-measures ANOVA tests (FitzGerald et al., 2004). Tukey’s HSD testswere used post hoc detect any significant differences in element:Ca ratios among factor levels(e.g. years). RESULTS All six elements (Li, Mg,Mn, Co, Sr and Ba) were regularly detected at all sites andwere therefore included in all statistical analyses. In general, element:Ca ratios metboth within-group normality (Kolmogorov-Smirnov's test, P>0-05 in all cases) andhomogeneity of variances among groups (Levene’s test, P>0-05 in all cases); however,when assumptions were violated (e.g. Mn:Ca and Li:Ca among years), element:Caatios were transformed ln(x+1) prior to statistical analyses. Temporal variability of element:Ca: ratios were not significantly different amongyears (MANOVA: P>0-05). Although, higher variation in elements:Ca concentra-tions were observed for Mn:Ca and Co:Ca (Fig. 4), Mn:Ca presented a slightly higher FIG. 4. Lutjanus alexandrei mean+ s.E. (a) Li:Ca, (b) Mg:Ca, (c) Mn:Ca, (d) Co:Ca, (e) Sr:Ca and (f) Ba:Caratios for different years (2010,2011 and 2012) in the same estuarine area(RF). TABLE II. Results of one-way ANOVA test for differences in element:Ca concentrations of (Li,Mg, Mn, Co, Sr and Ba) in Lutjanus alexandrei otoliths collected among coastal locations IT,OL, SA and SM (n=40) and between estuarine and adjacent coastal area RF and SI (n=20) Otolith area Source Element d.f. MS F P Edges Coastal locations Li:Ca 3 011 112 >005 Mg:Ca 3 4903 0-49 >005 Mn:Ca 3 000 056 >0-05 Co:Ca 3 001 3.95 <0-05 Sr:Ca 3 1612423 1.96 >0-05 Edges Estuarine v. coastal Ba:Ca 3 1-32 6-33 <001 Li:Ca 1 015 0-97 >0-05 Mg:Ca 289.71 1-38 >005 Mn:Ca 0·22 1589 <0·001 Co:Ca 001 1-20 >0-05 Sr:Ca 1823971 12·19 <0.01 Ba:Ca 2-93 542 <0.05 IT, Itamaraca; OL, Olinda; SA, Santo Antonio; SI, Sirinhaem;SM, Sao Miguel. trend for means (025, 0-32 and 0-39umol mol-1) in consecutive years (2010, 2011and 2012). Co:Ca ratios also displayed a large variability among the consecutive years(012,013,0-10umol mol-) though no trend was observed. Multi-elemental fingerprints differed significantly among coastal sampling locations(MANOVA: P<0·05). Univariate contrasts indicated that Co:Ca and Ba:Ca ratios var-ied significantly (ANOVA, P<0-05; Table II) among the four coastal sampling sites.Co:Ca ratios were significantly higher for OL compared to IT and SM, but not for SA,while Ba:Ca ratios OL site were significantly higher when compared to the other threecoastal locations (Tukey’s HSD test, P<005,Fig.5). n Multi-elemental fingerprints of similar sized L. alexandrei collected in estuarineand coastal waters were significantly different (MANOVA: P<005). Univariatecontrasts revealed that element:Ca ratios of Mn, Sr and Ba were significantly different(ANOVA,P<0-05, Table II) between the two regions. Mean Mn:Ca and Ba:Ca ratiosof L. alexandrei from estuarine areas (0.32 and 2-31 umol mol-1) were markedly higherthan observed for coastal reefs (0-11 and 1.54 umol mol-). In contrast mean Sr:Cafor L. alexandrei from the estuary (3552 umol mol-) was significantly lower thanobserved for individuals from the adjacent coastal area (4156 umol mol-)(Fig.6). Ontogenetic variability of (Mn and Ba) concentrations for L. alexandrei wasobserved across age classes (i.e. material accreted during each age interval), althoughfor Sr concentrations no trend was observed. Element:Ca ratios of Mn and Ba weresignificantly different across portions of the otolith that corresponded to differentyears (ANOVA P<0-05,Table III), however, Sr concentrations were not significantlydifferent across otolith portions (ANOVA, P>0·05, Table III). Mn:Ca ratios in theage-1 region of the otolith were significantly higher than all other ages (2-7 years),while age 2 years differed significantly from ages 5 to 7 years (Tukey’s HSD testP<0-05, Fig. 7). Similarly, age 1 year for Ba:Ca ratios were also significantly higherthan ages (4-7 years) while age 2 years differed significantly of ages 6 and 7 years(Tukey's HSD test P<005, Fig. 8). Additionally means and 95% c.I. of Mn:Ca andBa:Ca ratios observed in earlier trials from coastal sites were plotted as a reference FIG. 5. Lutjanus alexandrei mean+S.E. elemental concentrations ratio for (a) Ba:Ca and (b) Co:Ca in otolithedges that differed significantly among coastal sampling locations (see Table I for location codes). Bars withdifferent lowercase letters are statistically different from each other [Tukey’s honestly significant difference(HSD) test; P<0-05]. TABLE III. Results of one-way repeated-measures ANOVA test for differences of otolith pro-file of Mn, Sr and Ba across seven increments of same aged Lutjanus alexandrei individualscollected in coastal locations (IT, SA and SM, n=10) Otolith area Source Element d.f. MS F P Core to edges Coastal locations Mn:Ca 13.98 0·14 21.72 <0·001 Error 1.94 13.98 Sr:Ca 2.78 375488 1.51 >0-05 Error 22·20 248160 Ba:Ca 1.63 5816 6.91 <0·05 Error 13.04 8.41 IT, Itamaraca; SA, Santo Antonio; SM, Sao Miguel values for coastal Mn and Ba concentrations, representing a habitat break point(Figs7 and 8). Measurements of temperature and salinity at the two sites were pooled (representinga proxy of estuarine conditions where fish were collected) and varied from a mean of28.4(26.5-30.3) to 32.3(226-41) (Fig. 9). (a)0·4 0 Estuarine Coastal FIG. 6. Lutjanus alexandrei mean + S.E. elemental concentration ratios of (a) Mn:Ca, (b) Ba:Ca and (c) Sr:Ca inotolith edges that differed significantly between estuarine (RF) and adjacent coastal area (SI) (see Table Ifor location codes). DISCUSSION The element:Ca ratios in otoliths of juvenile L. alexandrei collected in the estu-ary showed a consistent pattern among the 3 years of this study, as no significanttemporal variations were found. Although interannual variations in otolith chemistryare frequently observed for fishes occupying estuaries and coastal environments FIG. 7. Lutjanus alexandrei mean +S.E. Mn:Ca elemental ratios for age groups (1-7 years) in otoliths of individ-uals collected in coastal areas [Itamaraca (IT), Santo Antonio (SA) and Sao Miguel (SM)]. Different lowercase letters are statistically different from each other [Tukey’s honestly significant difference (HSD) testP<0·05]. .__ represents a habitat break point of mean Mn:Ca concentrations (0-07 umolmol-) and (95%C.I.) observed for individuals previously sampled in coastal areas (n=30). FIG. 8. Lutjanus alexandrei mean+ S.E. Ba:Ca elemental ratios for age groups (1-7 years) in otoliths of individ-uals collected in coastal areas [Itamaraca (IT), Santo Antonio (SA) and Sao Miguel (SM)]. Different lowercase letters are statistically different from each other [Tukey's honestly significant difference (HSD) testP<0-05]. ___ represents a habitat break point of mean Ba:Ca concentrations (1-49 umol mol-1) andrepresent (95%c.I.) for individuals previously sampled in coastal areas (n=30). (Gillanders & Kingsford, 2000; Walther & Thorrold, 2009; Reis-Santos et al., 2012),several studies have also reported elemental stability across years (Gillanders, 2002b;Hamer et al., 2003), suggesting for these cases that physicochemical conditions withinthe study area were relatively stable over sampled time. Relative high salinity valuesfound in the sampled estuarine sites suggest that the sea water might be an importantphysical factor, influencing estuarine water, thus this tropical estuary seems to behaveas a branch of the sea based on salinity and temperature values, different from previousstudies in Brazil that have explored regions with higher freshwater discharges andstronger salinity gradients, such as observed on the South Brazilian coast (Albu-querque et al., 2012). Nevertheless, variations in elemental signatures of estuarine A. ASCHENBRENNER ET AL. Months (2012-2013) FiG. 9. Monthly mean temperatures () and salinities (◆) in estuary sites where Lutjanus alexandrei were col-lected from April 2012 to March 2013. fishes are likely to be system dependent, based on tides, water movements, hydrology,precipitation, upwelling and geochemical composition of the estuarine drainage basin(Elsdon et al., 2008). Also, anthropogenic influence and type of species (as elementconcentrations are species dependent) may influence chemical composition of fishotoliths (Gillanders & Kingsford, 2003; Chittaro et al., 2005,2006). Spatial variations in element:Ca ratios in otoliths of L. alexandrei from the fourcoastal collection sites were negligible. Apart from Co:Ca and Ba:Ca being signifi-cantly different at only one site (OL), present results suggest that element:Ca ratiosin the coastal areas are relatively similar even though certain sites are separated byover 200 km. Chemical similarity was also observed among otoliths of fishes sampledover small spatial scales by Gillanders et al. (2001) and Chittaro et al. (2005,2006)in oligotrophic coastal areas. Alternatively, differences over broader spatial locationswere found up to 1200 km (Secor & Zdanowicz, 1998; Thorrold et al., 1998), whileother studies have found no differences in otolith chemical composition amonglocations separated by 3000km (Proctor et al., 1995; Kalish et al., 1996). Thus,otolith chemistry is not necessarily a good predictor of distances among loca-tions in coastal areas (Elsdon et al., 2008), but to environmental water proper-ties (e.g. temperature and salinity) and physiographic process (e.g. rainfall andassociated runoff). Little variation in otolith chemistry found among sampledcoastal areas may be related to relatively homogeneous environmental conditions oralternatively movement of fishes among areas (Gillanders et al., 2001). Mn:Ca and Ba:Ca ratios present in recently accreted otolith material of L. alexandreicollected in the estuary were significantly greater than those in fish sampled in adjacentcoastal area, whereas Sr:Ca ratios showed the opposite trend with higher ratios forcoastal area. These three elements follow the same pattern observed in the literatureregarding comparisons among estuarine and coastal habitats (Gillanders & Kingsford, 1996; Rooker etal., 2004; Chittaro et al., 2005, 2006). Despite the fact that therelationship between environmental and physiological processes in otolith chemicalcomposition is poorly understood (Campana, 1999; Thresher, 1999), elements thatare under physiological regulation are less likely to reflect environmental variables,while elements that are incorporated into the otolith via substitution of calcium andincluded in interstitial spaces are likely to reflect environment parameters (i.e. Sr andBa). These last two elements have been widely used to investigate the movement andconnectivity of fishes between estuarine and coastal environments (Elsdon & Gillan-ders, 2004; de Vries et al., 2005; Walther & Thorrold, 2006). Mn has been used as anenvironmental indicator, particularly in estuarine habitats (Gillanders & Kingsford,2000, 2003; Reis-Santos et al., 2012), however, caution is needed in the interpretationof Mn:Ca otolith ratios, as the mechanisms regulating incorporation are still not fullyunderstood (Miller, 2009). Life-history transects of several elements decreased with increasing age for adult(age 7years) L. alexandrei inhabiting coastal areas, and observed changes in ele-ment:Ca ratios appear to track the movement of individuals from waters of higher(estuary) to lower (coastal) trace metal availability. Ba:Ca and Mn:Ca showed similarpatterns, with higher element:Ca ratios in the first year, subsequent decrease untilage 4 years, and similar values from age 5 tot o7 /years. Contrary to Ba and Mn, nodifference was found for Sr:Ca along otolith transects, this pattern may be expected asthe salinity in the studied estuary is depressed, but not low enough to overwhelm somephysiologically-mediated variance given that mixing curves of Sr:Ca are generallycurved with the largest change at lower salinities (i.e. lower than 20) (Albuquerqueetal., 2012). Although Sr has often been successfully used to infer habitat changealong a salinity gradient (Thorrold et al., 1997; Rooker et al., 2004), care is necessarywhen a stronger salinity gradient between habitats is lacking (as in this study), suggest-ing that Sr:Ca might be influenced by endogenous factors such as ontogeny (Fowleret al., 1995; Brown & Severin, 2009; Walther et al., 2010), growth rates (Sadovy &Severin, 1994), or a mix of both (Walther et al., 2010). Further work is necessary toassess the importance of these factors on otolith accumulation. Despite confoundingfactors, these results seem to confirm that L. alexandrei occupy estuaries during theirfirst year of life, moving to areas influenced by coastal processes as early as age 2 yearsas inferred from age studies (Aschenbrenner & Ferreira, 2015). Yet for general conclu-sions related to emigration patterns, larger sample sizes may be required. Ontogeneticshifts from estuarine to coastal areas have been described directly (markers) (Chittaroet al., 2006) and indirectly (UVC) for other snapper species in the western AtlanticOcean (Faunce & Serafy, 2007, 2008; Jones et al., 2010; Moura et al., 2011). Similarto L. alexandrei, certain congeners [e.g. schoolmaster snapper Lutjanus apodus (Wal-baum 1792)] use estuarine mangrove prop-root habitats during early life, moving outto coastal reef environments as sub-adults or adults (Rooker, 1995;Nagelkerken et al.,2000; Cocheret de la Moriniere et al., 2003). Present results show a similar patternfor L. alexandrei. Examining habitat-specific and age-specific variation in element:Caratios allow inference of potential movement patterns of L. alexandrei between estu-arine and coastal areas in Brazil. This life-history model is supported by a positiverelationship between size and age, and depths for Lutjanidae on the north-easternBrazilian coast (Fredou & Ferreira, 2005; Moura et al., 2011; Aschenbrenner &Ferreira, 2015). Along the north-eastern coast of Brazil, lutjanids are one of the main componentsof artisanal fisheries (Rezende et al., 2003; Fredou et al., 2009a, b). In the tropicalsouth-west Atlantic Ocean, estuarine areas harbour mangrove forests that constituteessential habitats for juvenile fishes. In Brazil, despite the existence of various envi-ronmental laws to protect mangroves, this ecosystem has been affected by a varietyof anthropogenic activities (Magrisi & Barreto, 2010). Although in Brazil there arenot concrete estimates, the occupation of the coastal zone has dramatically increased,exerting diverse and numerous stresses on coastal ecosystems. The impacts thatthreaten the future of Brazilian mangroves include the diversion of freshwater flows,deterioration of water quality caused by pollutants and nutrients as well as conversionfor development activities such as agriculture, aquaculture (mainly by shrimp farms),salt extraction and infrastructure, all of which contribute to the degradation and defor-estation process (Santos et al., 2014). The present results indicate that ontogeneticshifts between estuarine and coastal habitats may occur for L.alexandrei and thatthese habitats are essential for recruitment to the adult population (Aschenbrenner &Ferreira, 2015). Connectivity integrity between juvenile and adult habitats is thus anessential consideration for fishery managers and should be included in managementplans as well as other customary fishery management measures. We thank Conselho Nacional de Desenvolvimento Cientifico (CNPq) for sandwichGrant to A.A. Programa de P6s-Graduacao em Oceanografia da Universidade Federal dePernambuco-UFPE and Centro de Pesquisa e Gestao de Recursos Pesqueiros do LitoralNordeste-CEPENE/ICMBIO for laboratory and facilites. S. Marques for help in samplecollection. A special thanks to S. Zhang for assistance with the LA-ICPMS and all staff of theFisheries Ecology Laboratory at Texas A&M University at Galveston. We also acknowledgeCoordenacao de Aperfeicoamento de Pessoal de Nivel Superior - CAPES for financial supportto A.A. References Albuquerque, C. Q., Miekeley,N., Muelbert,J. H., Walther, B. D. & Jaureguizar,A. J.(2012).Estuarine dependency in a marine fish evaluated with otolith chemistry. Marine Biology159,2229-2239. doi: 10.1007/s00227-012-2007-5 Aschenbrenner, A. & Ferreira, B. P. (2015). Age, growth and mortality of Lutjanus alexandreiin estuarine and coastal waters of the tropical south-western Atlantic. Journal ofAppliedIchthyology 31, 57-64. doi: 10.1111/jai.12633 Brown,R. J. & Severin, K. P. (2009). Otolith chemistry analyses indicate that water Sr:Ca is theprimary factor influencing otolith Sr:Ca for freshwater and diadromous fish but not formarine fish. Canadian Journal of Fisheries and Aquatic Sciences 66, 1790-1808. doi:10.1139/F09-112 Campana, S. E. (1999). Chemistry and composition of fish otoliths: pathways, mechanisms andapplications. Marine Ecology Progress Series 188, 263-297. doi: 10.3354/meps188263 Chittaro, P. M., Usseglio, P., Fryer, B. J. & Sale, P. F. (2005). Using otolith microchemistryof Haemulon flavolineatum (French grunt) to characterize mangroves and coral reefsthroughout Turneffe Atoll, Belize: difficulties at small spatial scales. Estuaries 28,373-381.doi: 10.1007/BF02693920 Chittaro, P. M., Usseglio,P.,Fryer, B. J.& Sale,P.F.(2006). Spatial variation in otolith chemistryof Lutjanus apodus at Turneffe Atoll, Belize. Estuarine, Coastal and Shelf Science 67,673-680. doi: 10.1016/j.ecss Cocheret de la Moriniere,E.,Pollux, B. J. A., Nagelkerken, I. & van der Velde,H. G.(2003). Dietshifts of Caribbean grunts (Haemulidae) and snappers (Lutjanidae) and the relation withnursery-to-coral reef migrations. Estuarine, Coastal and Shelf Science 57, 1079-1089.doi: 10.1016/S0272-7714(03)00011-8 Elsdon, T. S. & Gillanders, B. M. (2004). Fish otolith chemistry influenced by exposure tomultiple environmental variables. Journal of Experimental Marine Biology and Ecology313,269-284. doi: 10.1016/j.jembe.2004.08.010 Elsdon, T. S., Wells, B. K., Campana, S. E., Gillanders, B. M., Jones, C. M., Limburg, K. E.,Secor, D. H., Thorrold, S. R. & Walther, B. D. (2008). Otolith chemistry to describemovements and life-history parameters of fishes: hypotheses, assumptions, limitationsand inferences. Oceanography and Marine Biology: An Annual Review 46, 297-330.doi: 10.1201/9781420065756.ch7 Faunce, C. H. & Serafy,E. J.(2007). Nearsore habitat use by gray snapper (Lutjanus griseus) andbluestriped grunt (Haemulon sciurus): environmental gradients and ontogenetic shifts).Bulletin ofMarine Science 80, 473-495. doi: 10.1080/00028487.2014.911209 Faunce, C. H. & Serafy, J. E. (2008). Selective use of mangrove shorelines by snappers,grunts, and great barracuda. Marine Ecology Progress Series 356, 153-162. doi:10.3354/meps07231 Fernandes, C. A. F., Oliveira, P. G. V., Travassos,P. E. P. & Hazin, F. V.H. (2012). Reproductionof the Brazilian snapper, Lutjanus alexandrei Moura & Lindeman, 2007 (Perciformes:Lutjanidae), off the northern coast of Pernambuco, Brazil. Neotropical Ichthyology 10,587-592. doi: 10.1016/j.fishres.2010.10.003 FitzGerald, J. L.,Thorrold, S. R., Bailey, K. M., Brown, A. L. & Severin, K.P. (2004). Elemen-tal signatures in otoliths of larval walleye pollock (Theragra chalcogramma) from thenortheast Pacific Ocean. Fishery Bulletin 102,604-616. Fowler, A. J., Campana, S. E., Jones, C. M. & Thorrold, S.R. (1995). Experimental assessmentof the effect of temperature and salinity on elemental composition of otoliths using laserablation ICPMS. Canadian Journal of Fisheries and Aquatic Sciences 52, 1431-1441.doi: 10.1139/f95-137 Fredou, T. & Ferreira, B. P. (2005). Bathymetric trends of Northeastern Brazilian snappers.Brazilian Archives of Biology and Technology 48,787-800. doi: 10.1590/S1516-9132005000600015 Fredou, T., Ferreira, B. P. & Letourneur, Y. (2009a). Assessing the stocks of the primary snap-pers caught in Northeastern Brazilian reef systems. 1: traditional modeling approaches.Fisheries Research 99, 90-96. doi: 10.1016/j.fishres.2009.05.008 Fredou, T.,Ferreira, B. P. & Letourneur, Y. (2009b). Assessing the stocks of the primary snapperscaught in Northeastern Brazilian reef systems. 2- a multi-fleet age structured approach.Fisheries Research 99,97-105. doi: 10.1016/j.fishres.2009.05.009 Gibson,R.N. (1994). Impact of habitat quality and quantity on the recruitment of juvenile fishes.Netherlands Journal of Sea Research 32,191-206. doi: 10.1016/0077-7579(94)90040-X Gillanders, B. M.(2002a). Connectivity between juvenile and adult fish populations: do adultsremain near their recruitment estuaries? Marine Ecology Progress Series 240, 215-223.doi:10.3354/meps240215 Gillanders,B.M.(2002b). Temporal and spatial variability in elemental composition of otoliths:implications for determining stock identity and connectivity of populations. CanadianJournal of Fisheries and Aquatic Sciences 59, 1-11. doi: 10.1139/f02-040 Gillanders, B. M. (2005). Using elemental chemistry of fish otoliths to determine connectivitybetween estuarine and coastal habitats. Estuarine, Coastal and Shelf Science 64, 47-57.doi: 10.1016/j.ecss.2005.02.005 Gillanders, B. M. & Kingsford,M. J. (1996). Elements in otoliths may elucidate the contributionof estuarine recruitment to sustaining coastal reef populations of a temperate reef fish.Marine Ecology Progress Series 141, 13-20. doi: 10.3354/meps141013 Gillanders, B. M. & Kingsford, M. J.(2000). Elemental fingerprints of otoliths of fish maydistinguish estuarine ‘nursery'habitats. Marine Ecology Progress Series 201,273-286.doi: 10.3354/meps201273 Gillanders, B. M. & Kingsford, M. J. (2003). Spatial variation in elemental composition ofotoliths of three species of fish (family Sparidae). Estuarine, Coastal and Shelf Science57,1049-1064. doi: 10.1016/S0272-7714(03)00009-X Gillanders, B. M., Sanchez-Jerez, P., Bayle-Sempere, J. & Ramos-Espla, A. (2001). Traceelements in otoliths of the two-banded bream from a coastal region in the south-westMediterranean: are there differences among locations? Journal of Fish Biology 59,350-363. doi: 10.1006/jfbi.2001.1643 Hamer, P. A., Jenkins, G. P. & Gillanders, B. M. (2003). Otolith chemistry of juvenile snapperPagrus auratus in Victorian waters: natural chemical tags and their temporal variation.Marine Ecology Progress Series 263, 261-273. doi: 10.3354/meps263261 Jones,D. L., Walter, J.F., Brooks, E. N. & Serafy, J. E. (2010). Connectivity through ontogeny:fish population linkages among mangrove and coral reef habitats. Marine EcologyProgress Series 401, 245-258. doi: 10.3354/meps08404 Kalish, J. M., Livingston,M. E. & Schofield, K. A. (1996). Trace elements in the otoliths of NewZealand blue grenadier Macruronus novaezelandiae as an aid to stock discrimination.Marine and Freshwater Research 47,537-542. doi: 10.1071/MF9960537 Limburg, K. E., Walther, B. D., Lu, Z., Jackman, G., Mohan, J., Walther, Y., Nissling, A.,Weber, P. K.& Schmitt, A. K. (2015). In search of the dead zone: use of otolithsfor tracking fish exposure to hypoxia. Journal of Marine Systems 141, 167-178.doi: 10.1016/j.jmarsys.2014.02.014 Magrisi, R. A. & Barreto,R.(2010). Mapping and assessment of protection of mangrove habitatsin Brazil. Pan-American Journal of Aquatic Sciences 5, 546-556. Mateo, I., Durbin, E. G.,Appeldoorn, R. S., Adams, A. J., Juanes, F., Kingsley, R., Swart, P.& Durant,D. (2010). Role of mangroves as nurseries for French grunt Haemulon flavo-lineatum and schoolmaster Lutjanus apodus assessed by otolith elemental fingerprints.Marine Ecology Progress Series 402, 197-212. doi: 10.3354/meps08445 Miller, J. A. (2009). The effects of temperature and water concentration on the otolith incor-poration of barium and manganese in black rockfish Sebastes melanops. Journal of FishBiology 75, 39-60. doi: 10.1111/j.1095-8649.2009.02262.x Miller, J. M., Crowder, L. B. & Moser, M. L. (1985). Migration and utilization of estuarinenurseries by juvenile fishes: an evolutionary perspective. Contributions in Marine Science27(Suppl),338-352. Moura, R. L. & Lindeman, K. C. (2007). A new species of snapper (Perciformes: Lutjanidae)from Brazil, with comments on distribution of Lutjanus griseus and L. apodus. Zootaxa1422,31-43. Moura, R. L.,Francini, R. B., Chaves, E. M., Minte-Vera, C. V. & Lindeman,K. C. (2011). Useof riverine through reef habitat systems by dog snapper (Lutjanus jocu) in eastern Brazil.Estuarine, Coastaacga 'l and Shelf Science 95, 274-278. doi: 10.1016/j.ecss.2011.08.010 Nagelkerken, I., van der Veldea, G., Gorissena, M. W., Meijera, G. J., van’t Hofc, T. & denHartoga, C. (2000). Importance of mangroves, seagrass beds and the shallow coral reefas a nursery for important coral reef fishes, using a visual census technique.Estuarine,Coastal and Shelf Science 51, 31-44. doi: 10.1006/ecss.2000.0617 Nakamura, Y., Horinouchi, M., Shibuno, T., Tanaka, Y.,Miyajima, T., Koike, I., Kurokura, H.& Sano, M. (2008).Evidence of ontogenetic migration from mangroves to coral reefsby black-tail snapper Lutjanus fulvus: stable isotope approach. Marine Ecology ProgressSeries 355, 257-266. doi: 10.3354/meps07234 Proctor, C. H., Thresher, R. E., Gunn, J. S., Mills, D. J., Harrowfield, I. R. & Sie, S. H.(1995). Stock structure of the southern bluefin tuna Thunnus maccoyii: an investigationbased on probe microanalysis of otolith composition. Marine Biology 122, 511-526.doi: 10.1007/BF00350674 Reis-Santos,P.,Gillanders,B. M., Tanner,S. E., Vasconcelos,R. P.,Elsdon, T. S. & Cabral, H. N.(2012). Temporal variability in estuarine fish otolith elemental fingerprints: implicationsfor connectivity assessments. Estuarine, Coastal and Shelf Science 112, 216-224. doi:10.1016/j.ecss Rezende,S. M., Ferreira, B. P.& Fredou,T. (2003). A pesca de lutjanideos no nordeste do Brasil:Historico das pescarias,caracteristicas das especies e relevancia para o manejo. BoletimTecnico Cientifico do Cepene 11, 257-270. Rooker,J.R.(1995).Feeding ecology of the schoolmaster snapper, Lutjanus apodus (Walbaum),from southwestern Puerto Rico. Bulletin of Marine Science 56, 881-894. Rooker, J. R., Kraus, R. & Secor, D. H. (2004). Dispersive behaviors of black drum and reddrum: is otolith Sr:Ca a reliable indicator of salinity history? Estuaries 27, 334-441.doi:10.1007/BF02803389 ( Rooker, J . R., Secor, D. H ., D e metrio, G., S chloesser, R ., B lock, B. A. & Neilson, J. D . (2008). Natal homing and connectivity in A tlantic bluefin tuna populations. Science 332, 742-744. doi: 10.1126/science.1 1 61473 ) Rooker, J. R., Stunz, G. W., Holt, S. A. & Minello,T.J. (2010). Population connectivity of reddrum in the northern Gulf of Mexico. Marine Ecology Progress Series 407, 187-196.doi: 10.3354/meps08605 Sadovy, Y. & Severin, K. P. (1994).Elemental patterns in red hind (Epinephelus guttatus)otoliths from Bermuda and Puerto Rico reflected growth rate, not temperature. CanadianJournal of Fisheries and Aquatic Sciences 51, 133-141. doi: 10.1139/f94-015 Santos, L. C. M., Matos, R. H., Schaeffer-Novelli, Y., Cunha-Lignon, M., Bitencourt, M. D.,Koedam,N. & Dahdouh-Guebas,F. (2014).Anthropogenic activities on mangrove areas(Sao Francisco River Estuary, Brazil Northeast): a GIS-based analysis of CBERS andSPOT images to aid in local management. Ocean & Coastal Management 89, 39-50.doi: 10.1016/j.ocecoaman.2013.12.010 Secor, D. H. & Zdanowicz, V.S. (1998). Otolith microconstituent analysis of juvenile bluefintuna (Thunnus thynnus) from the Mediterranean Sea and Pacific Ocean. FisheriesResearch 36,251-256. Secor, D. H., Rooker, J. R., Zlokovitz, E. & Zdanowicz, V. S. (2001). Identification ofriverine, estuarine, and coastal contingents of Hudson River striped bass basedupon otolith elemental fingerprints. Marine Ecology Progress Series 211, 245-253.doi: 10.3354/meps211245 Sheaves, M. (1995). Large lutjanid and serranid fishes in tropical estuaries: are they adults orjuveniles? Marine Ecology Progress Series 129, 31-40. doi: 10.3354/meps129031 SPSS Inc. (1999). SPSS Base 5.0 for Windows User’s Guide. Chicago, IL: SPSS Inc. Sturrock, A. M., Trueman, C. N., Darnaude, A. M. & Hunter, E. (2012). Can otolith elementalchemistry retrospectively track migrations in fully marine fishes? Journal of Fish Biology81,766-795. doi: 10.1111/j.1095-8649.2012.03372.x Thorrold, S. R., Jones, C. M. & Campana, S. E. (1997). Response of otolith micro-chemistry to environmental variations experienced by larval and juvenile Atlanticcroaker (Micropogonias undulatus). Limnology and Oceanography 42, 102-111.doi: 10.4319/lo.1997.42.1.0102 Thorrold,S. R., Jones, C. M., Swart, P. K. & Targett, T.E. (1998). Accurate classification of juve-nile weakfish Cynoscion regalis to estuarine nursery areas based on chemical signaturesin otoliths. Marine Ecology Progress Series 173,253-265. doi: 10.3354/meps173253 Thresher,R.E. (1999).Elemental composition of otoliths as a stock delineator in fishes. Fish-eries Research 3,165-204. doi: 10.1016/S0165-7836(99)00072-7 de Vries, M. C.,Gillanders, B. M. & Elsdon, T.S. (2005). Facilitation of barium uptake into fishotoliths: influence of strontium concentration and salinity. Geochimica et CosmochimicaActa 69,4061-4072. doi: 10.1016/j.gca.2005.03.052 Walther, B. D. & Thorrold, S.R. (2006). Water, not food, contributes the majority of strontiumand barium deposited in the otoliths of a marine fish. Marine Ecology Progress Series311,125-130. doi: 10.3354/meps311125 Walther, B. D. & Thorrold, S.R. (2009). Inter-annual variability in isotope and elemental ratiosrecorded in otoliths of an anadromous fish. Journal of Geochemical Exploration 102,181-186. doi: 10.1016/j.gexplo.2008.10.001 Walther, B. D., Kingsford, M., O'Callaghan, M. & McCulloch,M. (2010). Interac-tive effects of ontogeny, food ration and temperature on elemental incorporationin otoliths of a coral reef fish. Environmental Biology of Fishes 89, 441-451.doi: 10.1007/s10641-010-9661-6 Wilkinson, L., Blank, G. & Gruber, C. (1996). Desktop Data Analysis with SYSTAT. EnglewoodCliffs, NJ: Prentice Hall. Woodcock, S. H., Munro, A. R., Crook, D. A. & Gillanders, B. M. (2012). Incorporation ofmagnesium into fish otoliths: determining contribution from water and diet. Geochimicaet Cosmochimica Acta 94, 12-21. doi: 10.1016/j.gca.2012.07.003 Yoshinaga, J., Nakama, A., Morita, M. & Edmonds, J. S. (2000). Fish otolith referencematerial for quality assurance of chemical analyses. Marine Chemistry 69, 91-97.doi: 10.1016/S0304-4203(99)00098-5 The Fisheries Society of the British Isles @ The Fisheries Society of the British Isles, Journal of Fish Biology 为了评估自然标记物在个体迁移活动中的适用性,本研究对巴西鲷鱼Lutjanus alexandrei幼年和成年个体的耳石化学组成进行了分析。在3年期间(2010-2012)在巴西东北海岸从河口(幼年期和亚成年期阶段)和沿海(亚成年期到成年期阶段)地区收集了研究个体。采用激光剥蚀电感耦合等离子体质谱(LA-ICPMS)技术,测定了Lutjanus alexandrei耳石切片中6种元素(7Li、24Mg、55Mn、59Co、88Sr和137Ba)。对耳石边缘化学组成分析表明,在连续三年(2010、2011和2012)中,河口L alexandrei幼年个体和亚成虫期个体的中的钙比值没有显著差异,说明调查产区的理化条件是暂时稳定的。除了两种元素(Ba和Co)外,元素与Ca元素的比值在L alexandrei 海岸栖息地与河口栖息地类似。相比之下,来自河口和沿海地区的相似大小的Lutjanus alexandrei的耳石化学组成显著不同(基于近期积累的数据)。在河口收集的Lutjanus alexandrei的耳石Mn:Ca和Ba:Ca含量均显著高于邻近海岸珊瑚礁的鱼类,而Sr:Ca含量则相反。在珊瑚礁上收集的成年个体(7岁以上)的耳石的Ca元素从核心到边缘,可以用来推测从河口向沿海地区迁移的时间(个体发生迁移)。根据观测到的Mn:Ca和Ba:Ca的降低模式,Lutjanus alexandrei在2岁后开始向更多的沿海生境(即较低的Ca元素比水域)迁移。这一物种观察到的模式突出表明,必须保持沿海鱼类栖息地之间的连通性,以维持渔业与鱼类种群的可持续发展。
关闭还剩15页未读,是否继续阅读?
上海凯来仪器有限公司为您提供《河口以及海岸环境中巴西鲷鱼鱼耳石中化学特征空间变化检测方案(激光剥蚀进样)》,该方案主要用于其他中化学特征空间变化检测,参考标准《暂无》,《河口以及海岸环境中巴西鲷鱼鱼耳石中化学特征空间变化检测方案(激光剥蚀进样)》用到的仪器有ESL213 灵活的激光剥蚀系统。
