当前位置: 其他 > 方案详情
酶、非酶分子中和频光谱检测方案(其它光谱仪)
检测样品 其他
检测项目 和频光谱
关联设备 共2种 下载方案
方案详情
采用立陶宛Ekspla公司的皮秒振动和频光谱测量系统(VS-SFG)对酶、非酶分子的表面化学,光谱学特性进行了实验研究并讨论了其可能的应用。
      The content of this thesis is an investigation into physicochemical, photophysical,and interfacial properties of β-galactosidase, a crucial enzyme, its conjugate with CDs,interaction of β-galactosidase with X-gal, and surface chemistry and spectroscopic studyof toxins, Cholera toxin B (CTB) and Fumonisin B1 (FB1). The objective of the work wasto understand the surface chemistry behavior of the important enzyme, conjugates andtoxins in a model systems representing vaguely cell membrane environments, to prove theactivity of the deposited enzyme, its conjugate, and toxins in a form of the monolayer. Wealso studied the effect of green LED light on the FB1 Langmuir monolayer which will beuseful for possible future treatment of fungal keratitis without any side effects. Furthermore, this approach can be employed to understand the property of transmembrane receptors, to study the cell adhesion, and its implications. Besides that, this information is relevant for the successful deposition of Langmuir-Blodgett (LB) film. The Langmuir monolayer isotherm of enzyme, conjugate and the toxin were studied using the surface chemistry and spectroscopy at the air-water/subphase interphase.      We employed the pressure (π)-area (A) isotherm measurement which is typicallythe very first step in the study of these enzymatic and non-enzymatic molecules floating atthe subphase surface as it gives useful information on the existence of different phases,phase transitions and the stability of Langmuir monolayer at fixed temperature and pH.       During our study we found that β-galactosidase as well as its conjugate form stableLangmuir monolayer. We observed that during the interaction of the enzyme with X-gal,its secondary structure changes. This does not mean that the overall structure of the enzymegets changed. This is because enzyme structure is determined by primary, secondary,tertiary, and quaternary structure. The interfacial study of CTB showed that the moleculeis very stable at the air-subphase interface. In performing surface chemistry andspectroscopic study of FB1 molecule, the interesting finding that came out of the FB1Langmuir monolayer investigation was that the analyte adopted stability (withoutirradiation of green LED light) at the monolayer and remained degraded with subsequenteffect of the green LED light (525 nm) at air-water interface.
关闭
北京欧兰科技发展有限公司为您提供《酶、非酶分子中和频光谱检测方案(其它光谱仪)》,该方案主要用于其他中和频光谱检测,参考标准《暂无》,《酶、非酶分子中和频光谱检测方案(其它光谱仪)》用到的仪器有Ekspla SFG 表面和频光谱分析系统、PG400 系列皮秒光学参量发生/放大器系统。
我要纠错
推荐专场
相关方案
