纳谱分析NanoChrom纳谱分析技术(苏州)有限公司NanoChrom Technologies (Suzhou) Co., Ltdwww.nanochrom.com 融合蛋白 (Fusion Protein)的分离 Time [min] Column: BioCore SEC-500, 5 um Dimension: 4.6×300mm Mobile phase: 150mM Phosphate Buffered Saline (pH 6.8) Flow rate: 0.35 mL/min Temperature: 30 ℃ Injection: 5 pL Detection: UV 280 nm Sample: Fusion Protein (1 mg/mL in water) 融合蛋白(fusion protein)有两种不同的含义,一种是通过DNA重组技术得到的两个基因重组后的表达产物,另一种是介导两个细胞质膜融合的一组蛋白,如在仙台病毒脂双层外侧小叶中含有的两种糖蛋白之一,介导病毒被膜与宿主细胞质膜的融合作用。另一种糖蛋白是血细胞凝集素神经酰胺酶。 两个不同的蛋白质既可以通过化学方法也可以通过基因的融合来连成一个大分子。Fusion proteins or chimeric (\kī-ˈmir-ik) proteins (literally, made of parts from different sources) are proteins created through the joining of two or more genes that originally coded for separate proteins. Translation of this fusion gene results in a single or multiple polypeptides with functional properties derived from each of the original proteins. Recombinant fusion proteins are created artificially by recombinant DNA technology for use in biological research or therapeutics.
关闭产品配置单
纳谱分析技术(苏州)有限公司为您提供《DNA疫苗,双功能酶(多功能酶)中融合蛋白检测方案(液相色谱柱)》,该方案主要用于预防类生物药品中含量测定检测,参考标准《暂无》,《DNA疫苗,双功能酶(多功能酶)中融合蛋白检测方案(液相色谱柱)》用到的仪器有null。
