氢溴酸右美沙芬中旋光性检测方案(旋光仪)
检测样品
化药制剂
检测项目
理化性质
关联设备
共1种
下载方案
Optical rotation of Dextromethorphan Hydrobromide in accordance with the U.S. Pharmacopeia, is
requested to be measured at 325 nm, however there is no emission line of 325 nm available in the polarimeter
using Na lamp or Hg lamp as light source. Therefore, for the measurement of optical rotation of
Dextromethorphan Hydrobromide, a polarimeter with halogen lamp as a light source and interference filter
(325 nm) has been usually used, but as shown in Fig. 1, the optical rotatory dispersion (ORD) spectrum, there
is a very steep slope in the short wavelength range near 325 nm, where even a very small error in the
wavelength of interference filter may cause a very large error in the optical rotation measurement, which will
makes the accurate measurements very difficult. On the other hand, if the measurement by using 365nm is
allowed, since no wavelength error is expected, the measurement of optical rotation can be implemented with
much higher accuracy. In this experiment, Dextromethorphan Hydrobromide was measured using
polarimeter with Hg lamp (365 nm), polarimeter with Halogen lamp and interference filter (325 nm) and
polarimeter with ORD attachment.
Application NotecopyrightOJASCO CorporationJASCO INTERNATIONAL CO.,LTD4-21, Sennin-cho 2-chome, Hachioji, Tokyo 193-0835, JapanTel:+81-42-666-1322.Fax:+81-42-665-6512 P-0001 Optical rotation of Dextromethorphan Hydrobromide measured using 365nm emission line of mercury lamp Introduction Optical rotation of Dextromethorphan Hydrobromide in accordance with the U.S. Pharmacopeia, isrequested to be measured at 325 nm, however there is no emission line of 325 nm available in the polarimeterusing Na lamp or Hg lamp as light source. Therefore, for the measurement of optical rotation ofDextromethorphan Hydrobromide, a polarimeter with halogen lamp as a light source and interference filter(325 nm) has been usually used, but as shown in Fig.1, the optical rotatory dispersion (ORD) spectrum, thereis a very steep slope in the short wavelength range near 325 nm, where even a very small error in thewavelength of interference filter may cause a very large error in the optical rotation measurement, which willmakes the accurate measurements very difficult. On the other hand, if the measurement by using 365nm isallowed, since no wavelength error is expected, the measurement of optical rotation can be implemented withmuch higher accuracy. In this experiment, Dextromethorphan Hydrobromidee was measured usingpolarimeter with Hg lamp (365 nm), polarimeter with Halogen lamp and interference filter (325 nm) andpolarimeter with ORD attachment. Keywords: Dextromethorphan Hydrobromide, Mercury lamp,Optical rotation,ORD spectrum Results Fig. 1 ORD spectrum of Dextromethorphan Hydrobromide Optical rotation (365 nm, 20°C): +2.5655° (by JASCO P-2000 with Hg lamp) Specific rotation [α]36520: +142.53 Optical rotation (325 nm, 20C): +4.7034° (by JASCO P-2000 with halogen lamp & interference filter) Specific rotation [o]3252: +261.30 Optical rotation (365 nm, 20℃):Specific rotation[o]36520:Optical rotation (325 nm, 20℃):Specific rotation[o]32520: +2.5706° (by JASCO P-2000 with ORD attachment) +142.8131 +4.8726° (by JASCO P-2000 with ORD attachment) +270.70 Optical rotation of Dextromethorphan Hydrobromide in accordance with the U.S. Pharmacopeia, is requested to be measured at 325 nm, however there is no emission line of 325 nm available in the polarimeter using Na lamp or Hg lamp as light source. Therefore, for the measurement of optical rotation of Dextromethorphan Hydrobromide, a polarimeter with halogen lamp as a light source and interference filter (325 nm) has been usually used, but as shown in Fig. 1, the optical rotatory dispersion (ORD) spectrum, there is a very steep slope in the short wavelength range near 325 nm, where even a very small error in the wavelength of interference filter may cause a very large error in the optical rotation measurement, which will makes the accurate measurements very difficult. On the other hand, if the measurement by using 365nm is allowed, since no wavelength error is expected, the measurement of optical rotation can be implemented with much higher accuracy. In this experiment, Dextromethorphan Hydrobromide was measured using polarimeter with Hg lamp (365 nm), polarimeter with Halogen lamp and interference filter (325 nm) and polarimeter with ORD attachment.
关闭
1/1
JASCO 公司为您提供《氢溴酸右美沙芬中旋光性检测方案(旋光仪)》,该方案主要用于化药制剂中理化性质检测,参考标准《暂无》,《氢溴酸右美沙芬中旋光性检测方案(旋光仪)》用到的仪器有JASCO P-2000旋光仪。
我要纠错
