纳谱分析NanoChrom纳谱分析技术(苏州)有限公司NanoChrom Technologies (Suzhou) Co., Ltdwww.nanochrom.com 单克隆抗体((IgG4) 的聚体分离 Time [min] Column: BioCore SEC-150, 5 um BioCore SEC-300, 5 pm BioCore SEC-500, 5 um Dimension: 4.6x300mm Mobile phase: 150mM Phosphate Buffered Saline (pH 6.8)Flow rate: 0.35 mL/min Temperature: 30℃ Injection: 5uL Detection: UV 280 nm Sample: lgG4 (16 mg/mL in water) Peaks: 1.lgG4 Aggregates →YY.YyYY=YY 2. 1gG4 型号 流出时间(lgG4) 峰数 峰纯度 (IgG4) SEC-150 6.631 min 3 98.48% SEC-300 7.731 min 5 98.48% SEC-500 8.922 min 6 98.50% Column Black: BioCoreTM SEC-300, 5 μmColumn Blue:TSK G3000Dimension:7.8× 300mmMobile phase:Phosphate Buffered Saline (pH 7.4)Flow rate:0.5 mL/minTemperature:-Injection:5 μLDetection:UV 280 nmSample:Monoclonal AntibodyPeaks:1. Monoclonal Antibody Aggregates2. Monoclonal Antibody色谱柱主峰拖尾因子峰数主峰纯度BioCore SEC-3001.202598.92%TSK G30001.419498.30%
关闭产品配置单
纳谱分析技术(苏州)有限公司为您提供《生物制药中单克隆抗体检测方案 》,该方案主要用于其他中单克隆抗体检测,参考标准《暂无》,《生物制药中单克隆抗体检测方案 》用到的仪器有纳谱分析 BioCore SEC-300色谱柱 水溶性SEC柱。
