KGM KYOTO ELECTRONICSMANUFACTURING CO.,LTD.TIQ-97067en-KcMKYOTO ELECTRONICSMANUFACTURING CO.,LTD. Application Memo Boric Acid in Luster Nickel Plating Solution Industry Inorganic chemical industryInstrument Automatic potentiometric titratorMeasurement methodNeutralization titration 1. Overview After adding saturated potassium ferrocyanide solution, pure water and mannitol to thesample, boric acid concentration is measured by titration with 0.1mol/L sodium hydroxidesolution. The endpoint is the maximum inflexion on the titration curve. The boric acidconcentration is calculated from two data of titration volumes of the sodium hydroxide at theendpoints. 2. Apparatus Main unit Automatic potentiometric titrator (preamplifier STD) Electrode pH glass electrode Ceramic reference electrode Temperature compensation electrode 3. Reagents Titrant 0.1mol/L sodium hydroxide solution Solvent Pure water Additive Saturated potassium ferrocyanide solution, Mannitol 4. Example Sample Titer Conc. (mL) (mL) (g/L) 1 2 2.0 13.5789 41.96 2.0 13.4175 41.46 Average 41.71 Titration curve- Please feel free to contact us for any further information.
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《电镀镍溶液中硼酸检测方案(自动电位滴定)》,该方案主要用于其他中其他检测,参考标准《暂无》,《电镀镍溶液中硼酸检测方案(自动电位滴定)》用到的仪器有AT-710M四通道旗舰型自动电位滴定仪、AT-710S豪华型自动电位滴定仪。
