检测样品 洗涤剂
检测项目 含量分析
阳离子表面活性剂含量的测定 应用资料表面活性剂分为阳离子表面活性剂、阴离子表面活性剂、两性表面活性剂和非离子表面活性剂。本应用资料使用两种检测方式(表面活性剂电极和粒子电荷检测器)测量洗涤剂中所含阳离子表面活性剂的含量。APAT-0162en京都電子工業株式会社KYOTO ELECTRONICSMANUFACTURING CO.,LTD. APAT-0162er Application Note Measurement of the cationic surfactants in bath detergentusing surfactant electrode and particle charge detector Industry Cosmetics & soap Instrument Automatic potentiometric titrator Measurement method Potentiometric titration/Ion association titration Standards QB/T 4969 1. Scope Surfactant is a compound having a hydrophibic parts in the molecule. Depending on theproperties of the hydrophilic part, surfactant is classified into cationic surfactant, anionicsurfactant, amphoteric surfactant, and nonionic surfactant. In these surfactants, cationic surfactants have a property which the hydrophilic group has apositive electric charge after ionic dissociation, whereas anionic surfactants have a negativecharge. Both of these electric charges react and produce association formation. The producedassociation formation is insoluble and precipitated in water by decreasing of electric chargeand increasing of hydrophobicity during the reaction. Potentiometric titration method uses thischemical reaction to directly titrate the ionic surfactant. This Application Note introduces thecase in which the cationic surfactants contained in bath detergent is measured by using twokinds of detectors (a surfactant electrode and a particle charge detector). 2. Precautions The sensing part of the surfactant electrode does not have a high resistance to organic solvents.Therefore this part should not be cleaned with organic solvents. After measurement, theelectrode should be rinsed with distilled water and wiped off water with paper towel from thesensing part of electrode. When the particle charge detector is used, immerse the probe in ethanol after eachmeasurement and clean by driving the piston for approximately 1 minute. After that,completely remove the ethanol by rinsing it out with distilled water before starting the nextmeasurement. 3. Post-measurement procedure When the surfactant electrode is used, remove the internal solution and rinse the inside withdistilled water several times by using dropper. After the water from inside, attach the suppliedprotective cap and keep it dry. In the case that the electrode is stored with distilled waterdeterioration of the electrode is accelerated due to elution of the ingredients elements of fromthe sensitive membrane into the solution. When the particle charge detector is used, immerse the probe into ethanol, and rinse by drivingthe piston for approximately 1 minute. Remove the ethanol by rinsing with distilled water, andwipe off away water with a paper towel from the probe and keep the probe dry. 4. Apparatus ·Automatic potentiometric titrator (preamplifier : STD) ·Combined surfactant electrode (Internal liquid: 3.3mol / L potassium chloride solution) ·Particle charge detector 5. Reagents Titrant:0.002nmol/L Dodecylbenzenesulfonic acid sodiumSolvent : Pure water 6. Procedure 1) Take 0.5 g of the bathwater detergent into a beaker. 2) Add 100mL of distilled water. 3) Titrate the sample solution with 0.002mol/L of Dodecylbenzenesulfonic acid sodium, anddetect inflection point as end-point in titration curve. 7.Calculation Cationic surfactant (%)=EP1xTFxC1xK1/S EP1…·Titration volume of 1st end point (mL) TF···Factor of titrant =0.9913(Surfactant electrode) *=1.0091(Particle charge detector) * C1···Coefficient of concentration conversion=0.874mg/mL K1··Coefficient of unit conversion =0.1 S…·Sample size (g) *The factor was measured using 0.002 mol/L benzethonium chloride standard solution. 8. Example -Titration parameter- *Below parameter was used when measurement by using a surfactant electrode wasperformed.
还剩2页未读,是否继续阅读?
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《洗涤剂中阳离子表面活性剂含量检测方案(自动电位滴定)》,该方案主要用于洗涤剂中含量分析检测,参考标准《暂无》,《洗涤剂中阳离子表面活性剂含量检测方案(自动电位滴定)》用到的仪器有AT-710M四通道旗舰型自动电位滴定仪、AT-710S豪华型自动电位滴定仪。
