二氧化锰中含量(有效氧含量)的测定 应用资料在调整后的样品中加入水、盐酸和焦磷酸钠后,用0.01mol/L高锰酸钾滴定法测定总锰浓度。终点是滴定曲线上的最大拐点。总锰浓度由高锰酸钾的滴定体积计算得出。KGMKYOTO ELECTRONICSMANUFACTURING CO.,LTD.TIQ-99360enL Application Memo Total Manganese in Manganese Dioxide 1.Overview After adding water, hydrochloric acid and sodium pyrophosphate to the adjusted sample, total manganese concentration is measured by titration with 0.01mol/L potassium permanganate.al1The endpoint is the maximum inf l exion on the titration curve. The total manganese concentration is calculated from the titration volume of potassium permanganate. 2. Apparatus Main unit Automatic potentiometric titrator (preampl i fier STD) Electrode Platinum electrode Ceramic reference electrode 3.Reagents Titrant 0.01mol/L(N/20) potassium permanganate Solvent Water Additive 5mol/L hydrochloric acid, Sodium pyrophosphate (Sodium diphosphate) 10hydrate 4. Example —Measurement results一 Sample size Titer Concentration (g) (mL) (%) 1 0.098418 27.0000 60.393 2 0.098418 27.0171 60.431 3 0.098418 27.0210 60.440 Average 60.421 SD 0.025 RSD(%) 0.041 —Titration curve厂 Please feel free to contact us for any further i nformation.
产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《二氧化锰中含量(有效氧含量)的测定 应用资料》,该方案主要用于其他中二氧化锰检测,参考标准《暂无》,《二氧化锰中含量(有效氧含量)的测定 应用资料》用到的仪器有AT-710M四通道旗舰型自动电位滴定仪、AT-710S豪华型自动电位滴定仪、京都电子KEM 自动电位滴定仪控制操作软件 AT-Win。
