fredy-jason
第1楼2007/10/25
法文,老天,有极大难度啊!这里有一个链接地址:
http://translate.google.com/translate_t
你可以先将法文转成英文,在把英文转成中文,试验下吧!!
无名
第4楼2007/10/25
翻出來估計有些難度,因爲他的pdf是通過掃描的方式轉化的,需要將法文重新打出來,可能對計算機需要進行適當的輸入設置調整!
大力水手
第10楼2007/11/08
非常感谢各位的参与和帮助,这个问题我最后咨询了英国主管部门,他们的健回答如下,供各位参考。 同时大家如果有相关的问题可以自己去咨询。ROHS [rohs@nwml.gov.uk]
Dear Mr. Zhang
Thank you for contacting RoHS Enforcement UK.
Your enquiry was:
The Stud sensor locates wood and metal studs in walls.Use the Stud sensor for depths of up to 19mm+/-6mm accuracy. Now I can not sure whether the stud sensor belongs to monitoring and control instruments.Please give me a detail information whether the stud sensor needs to comply to RoHS requiement or not.Thanks!
Our reply is:
Our view would be that such a device was a detector with an alarm and similar to a smoke alarm in base function. We would view it as category 9 and out of scope.
Kind Regards
ROHS
The advice contained in this e-mail is based on the best and most up to date information available to us at the time. However, it is not a definitive opinion as only the courts can interpret legislation with any authority.
