1. Stern, M. and Weisert, E.D. Experimental observations on the relations between polarization resistance and corrosion rate. Proc. Amer. Sot. Test Mater. 1958, 59, 1280
2.Stern, M., Geary, A. L. (1957). ‘‘Electrochemical polarization: I. A theoretical analysis of the shape of polarization curves.’’ J. Electrochemical Soc., 104(1), 56–63.
3.Milton Stern A Method For Determining Corrosion Rates From Linear Polarization Data (Corrosion, Vol. 14, No. 9, 1958, pages 440t-444t)
