1.Effect of corrosion on the bond between steel and concrete: An overview Lundgren, K. Source: Magazine of Concrete Research, v 59, n 6, August, 2007, p 447-461
2.Deflection of RC beams under simultaneous load and steel corrosion Ballim, Y.; Reid, J.C.; Kemp, A.R. Source: Magazine of Concrete Research, v 55, n 4, August, 2003, p 405-406
3.Behavior of steel reinforcement under the effect of strong cathodic or anodic polarizations Gonzalez, J.A.,Ramirez, E.; Bautista, A. Source: Magazine of Concrete Research, v 50, n 3, Sep, 1998, p 201-208
4.Use of the coulostatic method for measuring corrosion rates of embedded metal in concrete Rodriguez, P. ,Gonzalez, J.A. Source: Magazine of Concrete Research, v 46, n 167, Jun, 1994, p 91-97
5.RILEM. 1994. Draft recommendation for repair strategies for concrete structures damaged by reinforcement corrosion. Materials and Structures, 27: 415–436.
