服装疵点英语词汇 服装疵点英语词汇 回页首 ——http://www.garmentbbs.cn,Jandy Zhu 编辑 armhole pucker 袖窿皱,夹圈皱 back vent unmeet 背叉豁 bad join stitching,poor repair stitching 驳线不良,接线不良 broken hole 破洞 broken stitching 断线 broken yarn 断纱 bubble 起泡 bump at placket edge 筒边钮门位突起 center back ride up 后中起吊 center back seam pulling 后中起吊 checks not match 不对格 collar points high / low 领尖高低 collar stand away from neck 领离脖 color deviation 色差 color fading 褪色 color fastness problem 褪色问题 color fibre woven in 杂色纤维织入 color shading within one garment 衣服裁片色差 color shading 色差 color thread end left inside 藏色线 color too dull / bright 颜色太哑/闪 color yarn 杂色纱 crease line leans to inside 烫迹线内撇 crease line leans to outside 烫迹线外撇 crease mark 摺痕 crossed back vent 背叉搅 crotch cross unmatch 下裆十字骨错位 crumple at top collar 领面起泡 cuff edge not level 鸡英袖口高低 dart point crumple 省尖起泡 dirty dot (较小的)污点 dirty mark,dirty stain 污渍,污迹 dirty spot (较大的)污点 drop needle 漏针,抽针,抽条,抽窿 empty hem 边缘缺棉 excess extension 突咀 excessive thread end 多余的线头 fabric defect 布疵 fabric too close to zipper 面布车得太贴近拉链 facing leans out from front edge 前襟止口反吐 fly up 飞起,翘起 glaze mark (熨烫)起镜 grin 露齿笑,裂口笑 hem not level 高低脚 hiking up 起吊 horizontal seams not level 水平缝骨不对称 incorrect linking 错误的连接 inner cuff visible/exposed 介英反光(止口反吐) iron mark 烫痕 knot 结头 lapel roll line not straight 驳口不直 lining too full / tight 里布太多/太紧 loom fly飞花织入 looping 起耳仔 major defect 大疵,严重疵点 material defect 布疵 minor defect 小疵,轻微疵点 mix color yarn 杂色纱织入 neck drop pucker 筒顶起皱 needle damage 车针导致的(布料)损坏 needle hole 针孔 off grain 布纹歪 oil stain 油渍 open seam 爆口 outseam / inseam pulling 吊脚 overlapping collar 叠领 overlapping lips 叠唇 overlapping stitching 驳线 overpress 熨烫过度 overwash 洗水过度 padded cotton uneven 絮棉不均 pilling 起球 placket bottom spread open 筒脚张开 placket wavy 门筒起波浪 pleated sewing 车缝打褶 pocket flap stick up 袋盖反翘 pocket opening spray open 口袋“笑口” pockets high / low 高低袋 poor back-stitching 回针不佳 poor ironing 烫工不良 pressing mark 烫痕,压痕 printing scrimp 印花裂痕 pucker 起皱 raw edge 散口 run off stitching (车缝)落坑 rust 锈迹 seam gapping 藏木虱,藏止口(烫工) seam overturn 止口反骨 seam slippage 爆口 seam twist 缝骨扭 seam wavy 缝骨起波浪 sewn in waste 车缝时混有杂物 shiny (烫)起镜 shoulder pucker 小肩皱 skip stitching 跳线 skirt flares uneven 裙浪不匀 slanting pocket 歪袋 sleeve leans to back 袖子偏后 sleeve leans to front 袖子偏前 slub 毛粒 smiling pocket 袋“笑口” stitching not in seam shadow 露暗线 stitching density uneven 线迹密度不均匀 stitching tension uneven 线迹张力不均匀 stripes not match 不对条 support stitching visible 辅助线外露 thick yarn 粗纱 thread end 线头 top collar too tight 领面紧 total different color 颜色完全不同 trapped color thread end 藏色线 twist leg 扭髀扭脚 twist 扭 under placket exposed 底筒外露 underply exposed 反光,止口反吐 underply turn out 反光,止口反吐 underpress 熨烫不够 undesirable odor 臭味,不可接受的气味 uneven collar 歪领 uneven color 深浅色 uneven dying 染色不均匀 uneven length of plackets 长短筒 uneven length of sleeves 长短袖 uneven lips 大小唇 uneven plaids 格仔不均匀 washing streak 洗水痕 water stain 水渍 wrinkle 起皱 wrinkles at collar band facing 下级领底皱 wrinkles at top collar 领面松 wrong color combo 颜色组合错误 wrong pattern 图案错误 wrong seam type 错误的缝骨类型 wrong size indicated 错码 yarn drawn out 抽纱 zipper not movable 拉链难以开合 zipper wavy 拉链起波浪
