Ilovenmr
第1楼2008/05/05
RDC,根据我的理解就是通过引入aligned media,使得本来能够在溶液中自由翻转(isotropic tumbling)的分子,在某个方向上受到限制,变成个相异性的anisotropic tumbling。因此一些本来由于isotropic tumbling而被平均化了的相互作用,不再能够被完全平均化,未被平均化的剩余部分就是rdc了。rdc的大小是和化学键与分子的相对orientation有关的,能够在计算分子结构的时候提供更多的restraint,得到的分辨率更高的structure.
RDC今年来在protein NMR 方面应用很多,网上有很多文献。
具体软件的使用,恐怕要靠你自己去读说明书了,如果身边有人会用更好。
rank
第10楼2008/09/05
RDC applications:
1) Small molecules. RDCs can be used to determine the molecular absolute configurations. For instance, one molecule might be R or S configurations, however, the C-H bond orientation will be different in these two configurations, thus allows the differentiation by RDCs. Remember, RDC is sensitive to internuclear vector orientation and distance. You may need at least 11 RDC measurements and the proposed molecular structures a priori.
2) Biomolecules. Structure refinement. That's to say, a low resolution structure has been determined either from NMR NOE or X-ray, the application of RDC will greatly boost the resolution as it provides an accurate and quantitative description over the vector orientation and distance. While NOE can only provide the semi-quantitative distance information
3) Protein-ligand interaction, i.e., transferred RDCs.
4) Dynamics
For PALES,
If you have the protein pdb structure, you may predict how the protein will align in the the specific media, so far only in Bicelle and Phage. However the accuracy of the prediction of electrostatic interactions is still far away from satisfactory.
Useage, in Unix/Linux command line
pales -Dtest.pdb
where test.pdb will be replaced by your structure.
If you have the RDC measurements, PALES will calculate the alignment tensors and the back-calculated RDCs. PALES provides a nice example, so you may run that first. And make sure the file format of your RDCs (text file) conform with PALES.
