看是不是你所需要的?一份中文两份英文!谢谢!
Phase transfer of platinum nanoparticles from aqueous to organic solutions using fatty amine molecules---jChemSci.pdf
Lamellar multilayer hexadecylaniline-modified gold nanoparticle films deposited by the Langmuir–Blodgett technique---ProcIndActSci.pdf
具有长碳链间隔层的纳米颗粒的二维排列-科学通报.pdf
谢谢热心应助!但请不要发名不符实的附件,三篇附件标题均已经改正。下次再这样将被当作欺骗,请注意。--handsomeland
andrew82chen 发表:1. Langmuir, 19 (17), 6987 -6993, 2003.
Phase Transfer of Surface-Modified Gold Nanoparticles by Hydrophobization with Alkylamines
http://pubs.acs.org/cgi-bin/abstract.cgi/langd5/2003/19/i17/abs/la034018+.html
2. Langmuir, 19 (15), 6277 -6282, 2003.
Investigation into the Interaction between Surface-Bound Alkylamines and Gold Nanoparticles.
http://pubs.acs.org/cgi-bin/abstract.cgi/langd5/2003/19/i15/abs/la034209c.html
3. Langmuir, 12 (20), 4723 -4730, 1996
Synthesis and Characterization of Hydrophobic, Organically-Soluble Gold Nanocrystals Functionalized with Primary Amines
http://pubs.acs.org/cgi-bin/abstract.cgi/langd5/1996/12/i20/abs/la960445u.html
