Sorry can not type Chinese in office. My 240 FS AAS is working well. But I would like to know how to calibrate the instrument? (just like HPLC system, every year we need system calibration on the pump, detector wavelength..)
I wonder that there maybe a detail method to calibrate the AAS. 1.工作波段(Wavelength):190-900nm 2.波长精度(Wavelength accuracy):±0.25nm 3.分辨率(Resolution):Better than 0.3nm 4.基线稳定性(Baseline stability):0.005A/30m 5.光源(Light source):Hollow cathode lamp:0-20mA ,
So I would like to know how to calibrate the AAS 240, to make my boss believe that before start testing, the AAS instrument is good to go.
