celan
第6楼2008/08/27
Protein NMR Spectroscopy: Principles and Practice
Summary
Protein NMR Spectroscopy provides a complete introduction to solution NMR spectroscopy for determining three-dimensional structures, dynamical properties, and intermolecular interactions of proteins. The Second Edition of this now classic text provides an authoritative presentation of the theoretical principles and experimental practices required for the most sophisticated applications of solution NMR spectroscopy to explicate the molecular basis of protein function, which in turn is increasingly important for understanding mechanisms of disease and for developing novel therapeutic approaches
Key Features
Bloch, density matrix and product operator theoretical formalisms
One-, two-, three-, and four-dimensional NMR spectroscopy
Semiclassical relaxation theory and chemical exchange effects
Practical aspects of experimental NMR spectroscopy
Proton homonuclear NMR experiments relevant for proteins and other biological macromolecules
13C and 15N heteronuclear NMR experiments relevant for proteins and other biological macromolecules
Extensive examples of NMR spectra for 1H, 15N, and 13C/15N proteins
Table of Contents
Acknowledgments
Preface
Chapter 1: Classical NMR Spectroscopy
1.1 Nuclear magnetism
1.2 The Bloch equations
1.3 The one-pulse NMR experiment
1.4 Linewidth
1.5 Chemical shift
1.6 Scalar coupling and limitations of the Bloch equations
Chapter 2: Theoretical Description of NMR Spectroscopy
2.1 Postulates of quantum mechanics
2.1.1 The Schrödinger equation
2.1.2 Eigenvalue equations
2.1.3 Simultaneous eigenfunctions
2.1.4 Expectation value of the magnetic moment
2.2 The density matrix
2.2.1 Dirac notation
2.2.2 Quantum statistical mechanics
2.2.3 The Liouville-von Neumann equation
2.2.4 The rotating frame transformation
2.2.5 Matrix representations of the spin operators
2.3 Pulses and rotation operators
2.4 Quantum mechanical NMR spectroscopy
2.4.1 Equilibrium and observation operators
2.4.2 The one-pulse experiment
2.5 Quantum mechanics of multispin systems
2.5.1 Direct product spaces
2.5.2 Scalar coupling Hamiltonian
2.5.3 Rotations in product spaces
2.5.4 One-pulse experiment for a two-spin system
2.6 Coherence
2.7 Product Operator Formalism
2.7.1 Operator spaces
2.7.2 Basis operators
2.7.3 Evolution in the product operator formalism
2.7.3.1 Free precession
2.7.3.2 Pulses
2.7.3.3 Practical Points
2.7.4 Single quantum coherence and observable operators
2.7.5 Multiple quantum coherence
2.7.6 Coherence transfer and generation of multiple quantum coherence
2.7.7 Examples of product operator calculations
2.7.7.1 The spin-echo
2.7.7.2 INEPT
2.7.7.3 Refocussed INEPT
2.7.7.4 Spin-state selective polarization transfer
2.8 Averaging of the spin Hamiltonian and residual interactions
Chapter 3: Experimental Aspects of NMR Spectroscopy
3.1 NMR instrumentation
3.2 Data acquisition
3.2.1 Sampling
3.2.2 Oversampling and digital filters
3.2.3 Quadrature detection
3.3 Data Processing
3.3.1 Fourier transformation
3.3.2 Data manipulations
3.3.2.1 Zero-filling
3.3.2.2 Apodization
3.3.2.3 Phasing
3.3.3 Signal-to-noise ratio
3.3.4 Alternatives to Fourier transformation
3.3.4.1 Linear prediction
3.3.4.2 Maximum entropy reconstruction
3.4 Pulse techniques
3.4.1 Off-resonance effects
3.4.2 B1 inhomogeneity
3.4.3 Composite pulses
3.4.4 Selective pulses
3.4.5 Phase-modulated pulses
3.4.6 Adiabatic pulses
3.5 Spin decoupling
3.5.1 Spin decoupling theory
3.5.2 Composite pulse decoupling
3.5.3 Adiabatic spin decoupling
3.5.4 Cycling sidebands
3.5.5 Recommendations for spin decoupling
3.6 B0 field gradients
3.7 Water suppression techniques
3.7.1 Presaturation
3.7.2 Jump-return and binomial sequences
3.7.3 Spin lock and field gradient pulses
3.7.4 Post-acquisition signal processing
3.8 One-dimensional proton NMR spectroscopy
3.8.1 Sample preparation
3.8.2 Instrument setup
3.8.2.1 Temperature calibration
3.8.2.2 Tuning
3.8.2.3 Shimming
3.8.2.4 Pulse width calibration
3.8.2.5 Recycle delay
3.8.2.6 Linewidth measurement
3.8.3 Referencing
3.8.4 Acquisition and data processing
3.8.4.1 One-pulse experiment
3.8.4.2 Hahn-echo experiment
Chapter 4: Multi-dimensional NMR Spectroscopy
4.1 Two-dimensional NMR spectroscopy
4.2 Coherence transfer and mixing
4.2.1 Through-bond coherence transfer
4.2.1.1 COSY-type coherence transfer
4.2.1.2 TOCSY transfer through bonds
4.2.2 Through space coherence transfer
4.2.3 Heteronuclear coherence transfer
4.2.4 Coherence transfer under residual dipolar coupling Hamiltonians
4.3 Coherence selection, phase cycling and field gradients
4.3.1 Coherence level diagrams
4.3.2 Phase cycles
4.3.2.1 Selection of a coherence transfer pathway
4.3.2.2 Saving time
4.3.2.3 Artifact suppression
4.3.2.4 Limitations of phase cycling
4.3.3 Pulsed field gradients
4.3.3.1 Selection of a coherence transfer pathway
4.3.3.2 Artifact suppression
4.3.3.3 Limitations of pulsed field gradients
4.3.4 Frequency discrimination
4.3.4.1 Frequency discrimination by phase cycling
4.3.4.2 Frequency discrimination by pulsed field gradients
4.3.4.3 Aliasing and folding in multi-dimensional NMR spectroscopy
4.4 Resolution and sensitivity
4.5 Three and Four dimensional NMR Spectroscopy
celan
第7楼2008/08/27
Chapter 5: Relaxation and Dynamic Processes
5.1 Introduction and survey of theoretical approaches
5.1.2 Relaxation in the Bloch equations
5.1.2 The Solomon Equations
5.1.3 Random-phase model for transverse relaxation
5.1.4 Bloch, Wangsness and Redfield Theory
5.2 The Master Equation
5.2.1 Interference Effects
5.2.2 Like spins, unlike spins, and the secular approximation
5.2.3 Relaxation in the rotating Frame
5.3 Spectral Density Functions
5.4 Relaxation Mechanisms
5.4.1 Intramolecular dipolar relaxation for IS spin system
5.4.2 Intramolecular dipolar relaxation for scalar coupled IS spin system
5.4.3 Intramolecular dipolar relaxation for IS spin system in the rotating frame
5.4.4 Chemical shift anisotropy and quadrupolar relaxation
5.4.5 Relaxation interference
5.4.6 Scalar relaxation
5.5 Nuclear Overhauser Effect
5.6 Chemical Exchange Effects in NMR Spectroscopy
5.6.1 Chemical exchange for isolated spins
5.6.2 Qualitative effects of chemical exchange in scalar coupled systems
Chapter 6: Experimental 1H NMR Methods
6.1 Assessment of the 1D 1H Spectrum
6.2 COSY-type experiments
6.2.1 COSY
6.2.1.1 Product operator analysis.
6.2.1.2 Experimental protocol
6.2.1.3 Processing
6.2.1.4 Information content
6.2.1.5 Quantitation of scalar coupling constants in COSY spectra
6.2.1.6 Experimental variants
6.2.2 Relayed COSY
6.2.2.1 Product operator analysis.
6.2.2.2 Experimental protocol
6.2.2.3 Processing.
6.2.2.4 Information content.
6.2.3 Double-relayed COSY
6.3 Multiple Quantum Filtered COSY
6.3.1 2QF-COSY
6.3.1.1 Product operator analysis.
6.3.1.2 Experimental protocol
6.3.1.3 Processing.
6.3.1.4 Information content
6.3.2 3QF-COSY
6.3.2.1 Product operator analysis
6.3.2.2 Experimental protocol and processing
6.3.2.3 Information content
6.3.3 E-COSY
6.3.3.1 Product operator analysis
6.3.3.2 Experimental protocol
6.3.3.3 Processing
6.3.3.4 Information content
6.3.3.5 Experimental variants
6.4 Multiple Quantum Spectroscopy
6.4.1 2Q spectroscopy
6.4.1.1 Product operator analysis
6.4.1.2 Experimental protocol
6.4.1.3 Processing
6.4.1.4 Information content
6.4.2 3Q spectroscopy
6.4.2.1 Product operator analysis
6.4.2.2 Experimental protocol and processing
6.4.2.3 Information content
6.5 TOCSY
6.5.1 Product operator analysis
6.5.2 Experimental protocol
6.5.3 Processing
6.5.4 Information content
6.5.5 Experimental variants
6.6 Cross-relaxation NMR experiments
6.6.1 NOESY
6.6.1.1 Product operator analysis.
6.6.1.2 Experimental protocol
6.6.1.3 Processing.
6.6.1.4 Information content.
6.6.1.5 Experimental variants.
6.6.2 ROESY
6.6.2.1 Product operator analysis
6.6.2.2 Experimental protocol and processing
6.6.2.3 Information content
6.6.2.5 Experimental variants
6.7 1H 3D experiments
6.7.1 Experimental protocol
6.7.2 Processing
6.7.3 Information content
6.7.4 Experimental variants
Chapter 7: Heteronuclear NMR Experiments
7.1 Heteronuclear correlation NMR spectroscopy
7.1.1 Basic heteronuclear correlation experiments
7.1.1.1 The HMQC experiment
7.1.1.2 The HSQC experiment
7.1.1.3 The constant-time HSQC experiment
7.1.1.4 Comparison of HMQC and HSQc spectra
7.1.2 Additional considerations in HMQC and HSQC experiments
7.1.2.1 Phase cycling and artifact suppression
7.1.2.2 13C scalar coupling and multiplet structure
7.1.2.3 Folding and aliasing
7.1.2.4 Processing HMQC and HSQC experiments
7.1.3 Decoupled HSQC, Sensitivity-enhanced HSQC, and TROSY experiments
7.1.3.1 The decoupled HSQC experiment
7.1.3.2 Sensitivity-enhanced HSQC
7.1.3.3 TROSY experiment
7.1.3.4 Comparison of decoupled HSQC, PEP HSQC, and TROSY experiments
celan
第8楼2008/08/27
7.1.3.5 Relaxation interference and TROSY spectra of larger proteins
7.1.4 Water suppression and gradient enhancement of heteronuclear correlation spectra
7.1.4.1 Solvent suppression
7.1.4.2 Gradient-enhanced HSQC and TROSY NMR spectroscopy
7.1.5 The constant-time 1H-13C HSQC experiment
7.2 Heteronuclear-edited NMR spectroscopy
7.2.1 3D NOESY-HSQC spectroscopy
7.2.1.1 3D 1H-15N NOESY-HSQC
7.2.1.2 3D 1H-13C NOESY-HSQC
7.2.2 3D TOCSY-HSQC spectroscopy
7.2.3 3D HSQC-NOESY and HSQC-TOCSY experiments
7.2.4 HMQC-NOESY-HMQC experiments
7.2.4.1 3D 15N/15N HMQC-NOESY-HMQC
7.2.4.2 4D 13C/15N HMQC-NOESY-HMQC
7.2.4.3 4D 13C/13C HMQC-NOESY-HMQC
7.2.4.4 Processing 4D HMQC-NOESY-HMQC spectra
7.2.5 Relative merits of 3D and 4D heteronuclear-edited NOESY spectroscopy
7.3 13C-13C correlations: the HCCH-COSY and HCCH-TOCSY experiments
7.3.1 HCCH-COSY
7.3.2 Constant-time HCCH-COSY
7.3.3 HCCH-TOCSY
7.4 3D Triple-resonance experiments
7.4.1 A prototype triple resonance experiment: HNCA
7.4.1.1 A simple HNCA experiment
7.4.1.2 The CT-HNCA experiment
7.4.1.3 The decoupled CT-HNCA experiment
7.4.1.4 The gradient-enhanced HNCA experiment
7.4.1.5 The gradient-enhanced TROSY-HNCA experiment
7.4.2 A complementary approach: the HN(CO)CA experiment
7.4.3 A straight-through triple resonance experiment: H(CA)NH
7.4.4 B ackbone correlations with the 13CO spins
7.4.4.1 HNCO
7.4.4.2 HN(CA)CO
7.4.5 Correlations with the Cb/Hb spins
7.4.5.1 CBCA(CO)NH
7.4.5.2 CBCANH
7.4.5.3 HNCACB
7.4.6 Additional considerations for triple resonance experiments
7.5 Measurement of scalar coupling constants
7.5.1 HNCA-J experiment
7.5.2 HNHA experiment
7.6 Measurement of residual dipolar coupling constants
Chapter 8: Experimental NMR Relaxation Methods
8.1 Pulse Sequences and Experimental Methods
8.2 Picosecond-nanosecond dynamics
8.2.1 Experimental methods for 15N laboratory-frame relaxation
8.2.2 Experimental methods 15N relaxation interference
8.2.3 Experimental methods for 13CH2D methyl laboratory-frame relaxation
8.2.4 Experimental methods for 13CO laboratory-frame relaxation
8.3 Microsecond-second dynamics
8.3.1 Lineshape analysis
8.3.2 ZZ-exchange spectroscopy
8.3.3 R1兿 rotating frame relaxation methods
8.3.4 CPMG relaxation methods
8.3.5 Chemical exchange in multiple quantum spectroscopy
8.3.6 TROSY-based approaches
Chapter 9: Larger Proteins and Molecular Interactions
9.1 Larger proteins
9.1.1 Protein deuteration
9.1.2 Relaxation in perdeuterated and random fractionally deuterated proteins
9.1.3 Sensitivity for perdeuterated proteins
9.1.4 2H Isotope shifts
9.1.5 Experiments for 1HN, 15N, 13Ca, 13C兝 and 13CO assignments in deuterated proteins
9.1.5.1 Constant-time HNCA for deuterated proteins
9.1.5.2 HN(CA)CB for deuterated proteins
9.1.5.3 Other experiments for resonance assignments
9.1.6 Sidechain 13C assignments in deuterated proteins
9.1.7 Sidechain 1H assignments
9.1.8 NOE restraints from deuterated proteins
9.1.8.1 4D HN-HN 15N/15N-separated NOESY experiment
9.1.8.2 13C/15N, 13C/13C and 15N/15N-separated NOESY experiments on random fractionally deuterated proteins
9.1.9 Selective protonation
9.2 Intermolecular interactions
9.2.1 Exchange regimes
9.2.2 Protein-ligand binding interfaces
9.2.2.1 Chemical shift mapping
9.2.2.2 Cross-saturation
9.2.2.3 Transverse relaxation and amide proton solvent exchange
9.2.3. Resonance assignments and structural restraints for protein complexes
9.2.3.1 Assignments and structures of proteins in protein-ligand complexes
9.2.3.2 Isotope edited/filtered NOESY to define intermolecular interfaces
9.3 Methods for rapid data acquisition
9.3.1 Non-uniform sampling
9.3.2 GFT NMR spectroscopy
9.3.3 Projection-reconstruction
Chapter 10: Sequential Assignment and Structure Calculations
10.1 Resonance assignment strategies
10.1.1 1H resonance assignments
10.1.2 Heteronuclear resonance assignments
10.2 Three dimensional solution structures
10.2.1 NMR derived structural restraints
10.2.1.1 NOE distance restraints
10.2.1.2 Dihedral angle restraints from scalar coupling constants
10.2.1.3 Dihedral angle restraints from isotropic chemical shifts
10.2.1.4 Restraints from residual dipolar coupling constants
10.2.1.5 Hydrogen bond restraints from amide proton-solvent exchange
10.2.1.6 Hydrogen bond restraints from trans-hydrogen bond scalar coupling constants
10.2.2 Structure determination
10.3 Conclusion
