第5楼2005/04/14
Notes on NMR Solvents
II. NMR Solvent Signals
Solvent 1H NMR Chemical Shift 13C NMR Chemical Shift
Acetic Acid 11.65 (1) , 2.04 (5) 179.0 (1) , 20.0 (7)
Acetone 2.05 (5) 206.7 (13) , 29.9 (7)
Acetonitrile 1.94 (5) 118.7 (1) , 1.39 (7)
Benzene 7.16 (1) 128.4 (3)
Chloroform 7.26 (1) 77.2 (3)
Dimethyl Sulfoxide 2.50 (5) 39.5 (7)
Methanol 4.87 (1) , 3.31 (5) 49.1 (7)
Methylene Chloride 5.32 (3) 54.00 (5)
Pyridine 8.74 (1) , 7.58 (1) , 7.22 (1) 150.3 (1) , 135.9 (3) , 123.9 (5)
Water (D2O) 4.8
III. NMR Water Signals
Acetone 2.8
Acetonitrile 2.1
Benzene 0.4
Chloroform 1.6
Dimethyl Sulfoxide 3.3
Methanol 4.8
Methylene Chloride 1.5
Pyridine 4.9
Water (D2O) 4.8
第8楼2005/04/20
NMR Water Signals
Signals for water occur at different frequencies in 1H NMR spectra depending on the solvent used. Listed below are the chemical shift positions of the water signal in several common solvents. Note that H2O is seen in aprotic solvents, while HOD is seen in protic solvents due to exchange with the solvent deuteriums.
Solvent Chemical Shift of H2O (or HOD)
Acetone 2.8
Acetonitrile 2.1
Benzene 0.4
Chloroform 1.6
Methanol 4.8
Pyridine 4.9
Water (D2O) 4.8
