不分流进样Purge time一般为0.75min,不宜太长,易造成峰拖尾。
zhoujingjp 发表:GC及MS中的参数根据什么来填写的?谁有没有一些资料让我看一下?
FRONT INLET (SPLIT/SPLITLESS) BACK INLET (SPLIT/SPLITLESS)
Mode: Splitless Mode: Split
Initial temp: 240 'C (On) Initial temp: 50 'C (Off)
Pressure: 7.04 psi (On) Pressure: 0.00 psi (Off)
Purge flow: 50.0 mL/min Total flow: 45.0 mL/min
Purge time: 2.00 min Gas saver: Off
Total flow: 53.9 mL/min Gas type: Helium
Gas saver: On
Saver flow: 20.0 mL/min
Saver time: 3.00 min
Gas type: Helium
