我来尝试一下: The purpose of calibration management is to do instruments measure controlling effectively. So the experimental results can be the right and actual data and information in industry.
我来尝试一下: The calibration management is designed to control the measurement of equipment/instrument/tools effectively, so as to relflect the actual data and information in the production correctly and objetively.
