熊猫宝宝
第2楼2008/11/05
Material Safety Data Sheet
1,4-Butanediol diglycidyl ether
Section 1 - Chemical Product and Company Identification
MSDS Name: 1,4-Butanediol diglycidyl ether
Synonyms:
Company Identification: shanghai aladdin reagent co.,Ltd
For information in China, call: 021-38953866
Emergency Number, China: 021-38953839
Section 2 - Composition, Information on Ingredients
CAS# Chemical Name: % EINECS#
2425-79-8 1,4-Butanediol diglycidyl ether 50-60% 219-371-7
Hazard Symbols: XN
Risk Phrases: 20/21 36/38 43
Section 3 - Hazards Identification
EMERGENCY OVERVIEW
Harmful by inhalation and in contact with skin. Irritating to eyes and skin. May cause sensitization by skin contact.
Potential Health Effects
Eye: Causes eye irritation.
Skin: Causes skin irritation. Harmful if absorbed through the skin. May cause skin sensitization, an allergic reaction, which becomes evident upon re-exposure to this material.
Ingestion: Harmful if swallowed. May cause irritation of the digestive tract.
Inhalation: Harmful if inhaled. May cause respiratory tract irritation.
Chronic:
Section 4 - First Aid Measures
Eyes: Flush eyes with plenty of water for at least 15 minutes, occasionally lifting the upper and lower eyelids. Get medical aid.
Skin: Get medical aid. Flush skin with plenty of water for at least 15 minutes while removing contaminated clothing and shoes.
Ingestion: Get medical aid. Wash mouth out with water.
Inhalation: Remove from exposure and move to fresh air immediately. If not breathing, give artificial respiration. If breathing is difficult, give oxygen. Get medical aid.
Notes to Physician:
Section 5 - Fire Fighting Measures
General Information: As in any fire, wear a self-contained breathing apparatus in pressure-demand, MSHA/NIOSH (approved or equivalent), and full protective gear.
Extinguishing Media: Use water spray, dry chemical, carbon dioxide, or chemical foam.
Section 6 - Accidental Release Measures
General Information: Use proper personal protective equipment as indicated in Section 8.
Spills/Leaks: Absorb spill with inert material (e.g. vermiculite, sand or earth), then place in suitable container.
Section 7 - Handling and Storage
Handling: Avoid breathing dust, vapor, mist, or gas. Avoid contact with skin and eyes.
Storage: Keep refrigerated. (Store below 4°C/39°F.) Store in a tightly closed container. Store in a dry area.
Section 8 - Exposure Controls, Personal Protection
Engineering Controls:
Use adequate ventilation to keep airborne concentrations low.
Exposure Limits
CAS# 2425-79-8:
Personal Protective Equipment
Eyes: Wear chemical splash goggles.
Skin: Wear appropriate protective gloves to prevent skin exposure.
Clothing: Wear appropriate protective clothing to prevent skin exposure.
Respirators: Follow the OSHA respirator regulations found in 29 CFR 1910.134 or European Standard EN 149. Use a NIOSH/MSHA or European Standard EN 149 approved respirator if exposure limits are exceeded or if irritation or other symptoms are experienced.
Section 9 - Physical and Chemical Properties
Physical State: Clear liquid
Color: yellow
Odor: Not available
pH: 7 (1000 g/l H2O)
Vapor Pressure: 10mmHg @20 deg C
Viscosity: <15 mPa s @25 deg C
Boiling Point: 266 deg C @760mmHg ( 510.80°F)
Freezing/Melting Point: Not available
Autoignition Temperature: Not available
Flash Point: > 112 deg C (> 233.60 deg F)
Explosion Limits: Lower: Not available
Explosion Limits: Upper: Not available
Decomposition Temperature:
Solubility in water: Soluble
Specific Gravity/Density: 1.100
Molecular Formula: C10H18O4
Molecular Weight: 202.25
Section 10 - Stability and Reactivity
Chemical Stability: Hygroscopic: absorbs moisture or water from the air.
Conditions to Avoid: Incompatible materials, exposure to moist air or water.
Incompatibilities with Other Materials Oxidizing agents, acids, bases.
Hazardous Decomposition Products Carbon monoxide, carbon dioxide.
Hazardous Polymerization Has not been reported.
Section 11 - Toxicological Information
RTECS#: CAS# 2425-79-8: EJ5100000
LD50/LC50: RTECS:
CAS# 2425-79-8: Draize test, rabbit, eye: 100 mg Moderate;
Draize test, rabbit, skin: 10 mg/24H Moderate;
Oral, mouse: LD50 = 1100 ug/kg;
Oral, rat: LD50 = 1134 mg/kg;
Skin, rabbit: LD50 = 1130 mg/kg;
Other: Oral, rat: LD50 = 2980 mg/kg
Carcinogenicity: 1,4-Butanediol diglycidyl ether - Not listed as a carcinogen by ACGIH, IARC, NTP, or CA Prop 65.
Other: The toxicological properties have not been fully investigated. See actual entry in RTECS for complete information.
Section 12 - Ecological Information
Not available Section 13 - Disposal Considerations
Dispose of in a manner consistent with federal, state, and local regulations.
Section 14 - Transport Information
IATA IMO RID/ADR
Shipping Name: Not regulated. Not regulated. Not regulated.
Hazard Class:
UN Number:
Packing Group:
Section 15 - Regulatory Information
European/International Regulations
European Labeling in Accordance with EC Directives
Hazard Symbols: XN
Risk Phrases:
R 20/21 Harmful by inhalation and in contact with skin.
R 36/38 Irritating to eyes and skin.
R 43 May cause sensitization by skin contact.
Safety Phrases:
S 26 In case of contact with eyes, rinse immediately with plenty of water and seek medical advice.
S 28B After contact with skin, wash immediately with plenty of water and soap.
S 37/39 Wear suitable gloves and eye/face protection.
WGK (Water Danger/Protection)
CAS# 2425-79-8: 2
Canada
CAS# 2425-79-8 is listed on Canada's DSL List
US Federal
TSCA
CAS# 2425-79-8 is listed on the TSCA Inventory.
Section 16 - Other Information
MSDS Creation Date: 7/16/1996
Revision #2 Date 5/13/2005
Revisions were made in Sections: General revision.
The information above is believed to be accurate and represents the best information currently available to us. However, we make no warranty of merchantibility or any other warranty, express or implied, with respect to such information, and we assume no liability resulting from its use. Users should make their own investigations to determine the suitability of the information for their particular purposes. In no event shall the company be liable for any claims, losses, or damages of any third party or for lost profits or any special, indirect, incidental, consequential, or exemplary damages howsoever arising, even if the company has been advised of the possibility of such damages
