阳线
第1楼2008/11/13
ASTM D 5225-98(Reapproved 2003) Standard Test Method for Measuring Solution Viscosity of Polymers with a Differential Viscometer
ASTM D 5225-98(R03)
阳线
第2楼2008/11/14
ASTM D 4927-02 Standard Test Methods for Elemental Analysis of Lubricant and Additive Components— Barium, Calcium, Phosphorus, Sulfur, and Zinc by Wavelength-Dispersive X-Ray Fluorescence Spectroscopy
中文名称:润滑油和添加物元素分析的测试方法 用X射线荧光光谱波长分散法测定钡、钙、磷、硫和锌
ASTM D 4927-02
发哥
第3楼2008/11/14
ASTM D1091-2000 润滑油和添加剂中磷含量的测试方法.pdf
ASTM D3231-2002 汽油中磷含量的试验方法.pdf
ASTM D4047-2000 喹啉磷钼酸盐法测定润滑油和添加剂中磷的试验方法.pdf
没有 ASTM D 5237-2005 织物软化剂评定的标准指南
ASTM D 515-88 活性磷总量
