阳线
第1楼2008/11/14
(请版主移帖到国外标准版面。)
ASTM D 256-06 Standard Test Methods for Determining the Izod Pendulum Impact Resistance of Plastics
http://www.instrument.com.cn/bbs/download.asp?ID=37718
ASTM D 570-98 Standard Test Method for Water Absorption of Plastics
http://www.instrument.com.cn/bbs/download.asp?ID=107086
ASTM D 638-03 Standard Test Method for Tensile Properties of Plastics
http://www.instrument.com.cn/bbs/download.asp?ID=30035
ASTM D 648-06 Standard Test Method for Deflection Temperature of Plastics Under Flexural Load in the Edgewise Position
http://www.instrument.com.cn/bbs/download.asp?ID=47651
阳线
第2楼2008/11/14
ASTM D 696-03 Standard Test Method for Coefficient of Linear Thermal Expansion of Plastics Between -30℃ and 30℃ with a Vitreous Silica Dilatometer
http://www.instrument.com.cn/bbs/download.asp?ID=59444
ASTM D 746-04 Standard Test Method for Brittleness Temperature of Plastics and Elastomers by Impact
http://www.instrument.com.cn/bbs/download.asp?ID=57645
ASTM D 785-03 Standard Test Method for Rockwell Hardness of Plastics and Electrical Insulating Materials
http://www.instrument.com.cn/bbs/download.asp?ID=62888
ASTM D 790-03 Standard Test Methods for Flexural Properties of Unreinforced and Reinforced Plastics and Electrical Insulating Materials
http://www.instrument.com.cn/bbs/download.asp?ID=30036
阳线
第3楼2008/11/14
ASTM D 792-00 Standard Test Methods for Density and Specific Gravity (Relative Density) of Plastics by Displacement
http://www.instrument.com.cn/bbs/download.asp?ID=55178
ASTM D 1044-08 Standard Test Method for Resistance of Transparent Plastics to Surface Abrasion
http://www.instrument.com.cn/bbs/shtml/20081114/1584970/
ASTM D 1238-04c Standard Test Method for Melt Flow Rates of Thermoplastics by Extrusion Plastometer
http://www.instrument.com.cn/bbs/shtml/20081114/1585051/
ASTM D 1591找不到。
阳线
第4楼2008/11/14
该帖子于 2008-11-14 12:15:46 被 hzsunmoon 删除,删除理由:double,合并帖子
