看看我变色酸法做的甲醛标线有什么问题?
气体检测
  • 变色酸0.1%,Tube No. Volume, mL
    NaHSO3(1%) Solution B(10ug/ml甲醛的1%的NaHSO3)
    Std1 4.0ml 0.00ml
    Std2 3.9ml 0.10ml
    Std3 3.7ml 0.30ml
    Std4 3.5ml 0.50ml
    Std5 3.3ml 0.70ml
    Std6 3.0ml 1.00ml
    然后每个加入6.00ml浓硫酸摇匀,2小时后在紫外-可见分光光度计,580nm处以水为参比测试,结果如下;
    Report time 2008-12-5 15:28:11
    Method E:\formaldehyde in furniture\method\ASTM
    D6007-2.MCN
    Batch name E:\formaldehyde in furniture\data\20081205.BCN
    Application Concentration 3.00(339)
    Operator
    Instrument Settings
    Instrument Cary 300
    Instrument version no. 9.00
    Wavelength (nm) 580.00
    Ordinate Mode Abs
    SBW (nm) 1.5
    Ave Time (sec) 0.100
    Beam mode Double auto select
    Beam interchange Normal
    Replicates 1
    Standard/Sample averaging OFF
    Weight and volume corrections OFF
    Fit type Linear
    Min R2 0.95000
    Concentration units ug
    Comments:
    Zero Report
    Read Abs nm
    ________________________________________________
    Zero (-0.0173) 580.00
    Calibration
    Collection time 2008-12-5 15:29:58
    Standard Concentration F Readings(ABS)
    ug
    Std 1 0.0000 0.0134
    Std 2 1.0000 0.0754
    Std 3 3.0000 0.1921
    Std 4 5.0000 0.3063
    Std 5 7.0000 0.4204
    Std 6 10.0000 0.5967
    Calibration eqn Abs=0.05805*Conc+0.01586
    Correlation Coefficient 0.99993
    Calibration time 2008-12-5 15:35:47
    Analysis
    Collection time 2008-12-5 15:35:47
    Sample Concentration F Readings
    mg/L
    MB-1 -0.0041 0.0156
    MB-2 -0.0229 0.0145
    MB-3 -0.0229 0.0145
    MB-4 -0.0190 0.0148
    MB-5 -0.0414 0.0135
    MB-6 -0.0265 0.0143
    MB-7 -0.0286 0.0142
    MB-8 -0.0267 0.0143
    MB-9 0.0150 0.0167
    MB-10 -0.0244 0.0144
    MB-11 -0.0134 0.0151
    MB-12 -0.0360 0.0138
    MB-13 -0.0252 0.0144
    MB-14 -0.0257 0.0144
    MB-15 -0.0088 0.0153
    MB-16 -0.0159 0.0149
    MB-17 -0.0143 0.0150
    MB-18 -0.0179 0.0148
    MB-19 0.0198 0.0170
    MB-20 -0.0252 0.0144
    MB-21 -0.0277 0.0142
    MB-22 -0.0402 0.0135
    Std 2 1.0273 0.0755
    Std 2 1.0268 0.0755
    Std 2 1.0303 0.0757
    Std 2 1.0290 0.0756
    Std 2 1.0284 0.0756
    Std 3 3.0373 0.1922
    Std 3 3.0223 0.1913
    Std 3 3.0250 0.1915
    Std 3 3.0220 0.1913
    Std 3 3.0203 0.1912
    Std 4 4.9840 0.3052
    Std 4 4.9859 0.3053
    Std 4 4.9881 0.3054
    Std 4 4.9838 0.3052
    Std 4 4.9864 0.3053
    Std 5 6.9923 0.4217
    Std 5 6.9751 0.4207
    Std 5 6.9704 0.4205
    Std 5 6.9635 0.4201
    Std 5 6.9640 0.4201
    Std 6 9.9910 0.5958
    Std 6 9.9862 0.5955
    Std 6 9.9862 0.5955
    Std 6 9.9311 0.5923
    Std 6 9.9328 0.5924
    这些点又重新测了,怎么误差那么大啊,从吸光度看都差不多,但是从等式算出来就不一样了,差别还比较大的?尤其是空白吸光度0.0145 ,算出来却是-0.0229,而Std 1 0.0000 0.0134; 0.0145比0.0134还大怎么是负值?
    另外根据这些能不能算检出限?怎么算?我算的怎么比空白还小很多啊?
  • yangjianqin
    第1楼2008/12/15
    从吸光度看都差不多,但是从等式算出来就不一样了,差别还比较大的。
    看不明白???????
    你能确保在样品配制过程中是否准确?是否超仪器检测的线性范围?
  • 做牛做马
    第2楼2008/12/16
    是不是你的仪器没有预热好啊,要不就是你每次测试的时候没有洗干净比色皿,
  • ☆真空★
    第3楼2008/12/17
    请问能把你适用的测试标准发个我一份吗?我也正想用变色酸测甲醛可是不知道用什么标准,发到我邮箱好吗谢谢了!邮箱地址:moreboshi@163.com
  • hxueren
    第4楼2008/12/19
    标准就是ASTM D 6007-2002
    kongxy1983 发表:请问能把你适用的测试标准发个我一份吗?我也正想用变色酸测甲醛可是不知道用什么标准,发到我邮箱好吗谢谢了!邮箱地址:moreboshi@163.com
  • lz20052006
    第5楼2009/01/20
    我也在用这个标准做哟!
    有时间交流一下,
  • 该帖子已被版主-核桃加2积分,加2经验;加分理由:谢谢分享,欢迎发帖
