suyou960921
第2楼2009/10/02
ICP-AES常用谱线及检出限
元素
波长
λ/nm
检出限
DL/(μg/mL)
主要光谱干扰
Ag
328.07
0.003
Al
309.27
396.15
237.34
308.22
0.008
0.01
0.01
0.025
V, Fe, Mg
Mo, Ca
Mn
As①
189.04
193.76
0.03
0.04
Al
Au
242.80
267.60
208.21
0.008
0.02
0.03
Mn
Ta
B
249.77
249.68
208.96
(182.59)
0.002
0.004
0.008
0.01
Fe
Mo
Ba
455.40
0.0002
Be
313.04
234.86
0.0001
0.0002
V
Bi
223.06
0.04
Ca
393.37
317.93
0.00002
0.003
Cd
214.44
228.80
226.50
0.002
0.002
0.003
Pt
As
Ni
Ce
413.76
0.02
Co
238.89
228.62
0.004
0.005
Fe
Cr
205.55
206.15
267.72
283.56
0.003
0.004
0.004
0.004
Bi, Zn, Pt
Pt
Fe
Cu
324.75
224.70
327.40
0.002
0.004
0.005
Dy
353.17
0.008
Er
337.27
0.005
Ti
Eu
381.97
0.001
Fe
238.20
239.56
259.94
0.002
0.002
0.002
Ga
294.36
0.02
Gd
342.25
335.05
0.007
0.01
Ge①
209.43
265.12
0.02
0.03
Ta, Hf
Hf
277.34
273.88
264.14
232.25
0.008
0.008
0.01
0.01
Cr, Fe
Ti, Mo, Fe
Fe, Mo
Mo
Hg①
194.23
(187.05)
253.65
0.02
0.02
0.05
V
Fe
Ho
345.60
0.004
Er
I
(178.28)
(183.04)
206.24
0.008
0.02
0.1
Cu, Zn
In
230.61
0.04
Ir
224.27
0.02
Cu
K
766.49
769.90
0.06
0.15
Cu
La
394.91
379.48
0.002
0.005
Ar
Fe
Li
670.78
0.002
Lu
261.54
291.14
219.55
0.0005
0.003
0.004
Er, Fe, V, Ni
Er, V
Mg
279.55
279.08
0.00005
0.02
Ti
Mn
257.61
259.37
0.0005
0.0008
Fe, Mo, Nb, Ta
Mo
202.03
0.004
Fe
Na
589.00
589.59
0.02
0.02
Ar
Nb
309.42
316.34
0.005
0.005
V
Nd
401.23
430.36
406.11
415.61
0.03
0.04
0.05
0.06
Ce, Nb, Ti
Pr
Ni
221.65
232.00
231.60
0.008
0.009
0.009
Co, W
Cr, Pt
Os
225.59
0.0004
Fe
P
213.62
214.91
(178.29)
0.05
0.05
0.1
Cu
Cu
I
Pb①
220.35
0.03
Pd, Sn
Pd
340.46
363.47
0.02
0.03
V, Fe, Mo, Zr
Co
Pr
390.84
422.30
0.02
0.025
Ce, U
Pt
214.42
203.65
204.94
265.95
0.02
0.03
0.04
0.04
Cd
Rh, Co
Rb
780.02
0.3
Re
221.43
227.53
0.006
0.006
Os, Pt, Pd
Ag
Rh
233.48
249.08
343.49
0.02
0.03
0.03
Sn
Fe
Ru
240.27
0.02
Fe
S
(180.73)
0.04
Al
Sb①
206.83
217.59
0.03
0.04
Cr, Ge, Mo
Co
Sc
361.38
0.0008
Se①
196.09
0.06
Pd
Si
251.61
212.41
288.16
0.008
0.01
0.015
V, Mo
Mo
Sm
359.26
428.08
0.02
0.04
Nd, Gd, V
Nd
Sn①
189.98
0.02
Ti
Sr
407.77
0.00008
La
Ta
226.23
240.06
0.03
0.03
Pd
Pt, Rh, Hf
Tb
350.92
0.02
Ru, V
Te①
214.28
0.04
Th
283.73
0.04
Fe
Ti
334.94
336.12
0.002
0.003
Cr, Nb
Tl
190.86
0.04
Mo, V
Tm
313.13
0.004
Be
U
385.96
409.01
424.17
0.08
0.1
0.1
Nd, Fe
V
309.31
310.23
292.40
0.003
0.003
0.004
Al
Ni
W
207.91
239.71
0.015
0.03
Ni, Cu
Y
371.03
0.001
Yb
328.94
211.67
212.67
0.001
0.005
0.005
Fe, V
Mo, Rh
Ir, Ni, Pd
Zn
202.55
206.19
213.86
0.002
0.003
0.005
Mg, Cu
Cr, Bi
Ni, V
Zr
343.82
339.20
349.62
0.002
0.002
0.003
Hf
Er, Th, Fe, Cr
Yt, Mn
注:1.波长下划横线者为最佳波长;
2.波长有()者需用真空光路。
①这些元素可用氢化法测定,其检出限比表中列出的检出限低100~200倍。
