第1楼2005/06/15
Although ROESY has the advantage compared to NOESY that enhancements for molecules of all weights are positive, and therefore there is no molecular weight at which ROEs are nearly zero, ROESY has the disadvantage that TOCSY artifact peaks can occur. This problem does not arise in a NOESY.
