1、 Pathways for Dye Diffusion in Wool Fibers Wortmann, F.-J., Wortmann, G., Zahn, H., Pathways for Dye Diffusion in Wool Fibers, Textile Res. J., 1997, 67, 720-4. 2、 Penetration of Alcohols into Wool and Hair as Studied by Fluorescence Microscopy Jurdana, L.E., Leaver, I.H., Penetration of Alcohols into Wool and Hair as Studied by Fluorescence Microscopy, Textile Res. J., 1992, 62, 463-8. 3、physical properties of wool fibers at various regains. Ⅶ. The binding of water in keratin M. Feughelman and A.R. Haly, The physical properties of wool fibers at various regains. Ⅶ. The binding of water in keratin. Textile Res. J., 1962, 32, 966-971.
