a. 機臺在啟動時無法找到SCSI-Bus,也就是說Voyager主機和工作站沒有建立起通訊,相關信息如下: Voyager:Starting the Workstation SCSI Server(WSS)... 068:005 [Pid 240] WSS Error:WSS ERROPN) Error openning target device The Workstation SCSI server was unlabel to open a path to the SCSI target device (TASC system) The possible causes are1)incorrect device name in open statement, (2)special device file not accessible due to privilege mask, and (3)conflict with exciting devices on the SCSI bus
b. 隨后的啟動信息顯示,與EDS相關的Weal_server 和與圖片處理相關的Wima_server沒有正常啟動(估计这个两个服务需要SCSI的通讯信息)
c. 在終端中執行"cfgadm -al"命令,顯示信息如下: AP_ID Type Receptacle Occupant condition C0 SCSI-bus connected configured unknow C0::dsk/c0t1d0 disk connected configured unknow C0::dsk/c0t6d0 CD-Rom connected configured unknow 并沒有看到與EDS 的Voyager主機相連的SCSI端口的信息。
