poorlittle
第2楼2010/01/12
The following is quoted from https://www.edqm.eu/en/page_630.php?rubrique=400 for your reference:
Question-
In Ph. Eur. section 2.6.12 under 4-4 GROWTH PROMOTION OF THE MEDIA. There is a statement that reads ''For solid media, growth obtained must not differ by a factor greater than 2 from the calculated value for a standardised inoculum''. Does the statement mean that the difference can be twice the calculated value of inoculum, or half the calculated value of inoculum?
Answer-
Your interpretation is correct. If the inoculum is 100 CFU then the recovery must be between 50 and 200 CFU.
For further information, please try to search with the keywords “not differ by a factor greater than” (with quotation mark)
影子
第4楼2010/01/12
也就是说这里的factor既有减少1/2,也有增加2倍的意思,如果回收率规定为100%,则测试结果在50%(100%/2)~200%(100%×2)之间就是合格的了.
