【求助】多环芳烃检测方面的一篇文献
气质联用(GCMS)
  • 悬赏金额:10积分状态:已解决
  • 求下面这篇期刊,不胜感激!
    作者:Martin Rose, Shaun White, Roy Macarthur, Rupert G Petch, Joseph Holland, and Andrew P Damant.
    题目:Single-Laboratory Validation of a GC-MS Method for the Determination of 27 Polycyclic Aromatic Hydrocarbons (PAHs) in Oils and Fats.
    期刊:Food Additives and Contaminants: Volume 24, Issue 6 June 2007 , pages 635 - 651.
    Abstract:
    A protocol for the measurement of 27 polycyclic aromatic hydrocarbons (PAHs) in vegetable oils by GC/MS has undergone single-laboratory validation. PAHs were measured in three oils (olive pomace, sunflower and coconut oil). Five samples of each oil (one unfortified, and four fortified at concentrations between 2 and 50 µg kg-1) were analysed in replicate (four times in separate runs). Two samples (one unfortified and one fortified at 2 µg kg-1) of five oils (virgin olive oil, grapeseed oil, toasted sesame oil, olive margarine and palm oil) were also analysed. The validation included an assessment of measurement bias from the results of 120 measurements of a certified reference material (coconut oil BCR CRM458 certified for six PAHs). The method is capable of reliably detecting 26 out of 27 PAHs, at concentration <2 µg kg-1 which is the European Union maximum limit for benzo[a]pyrene, in vegetable oils, olive pomace oil, sunflower oil and coconut oil. Quantitative results were obtained that are fit for purpose for concentrations from <2 to 50 µg kg-1 for 24 out of 27 PAHs in olive pomace oil, sunflower oil and coconut oil. The reliable detection of 2 µg kg-1 of PAHs in five additional oils (virgin olive oil, grapeseed oil, toasted sesame oil, olive margarine and palm oil) has been demonstrated. The method failed to produce fit-for-purpose results for the measurement of dibenzo[a,h]pyrene, anthanthrene and cyclopenta[c,d]pyrene. The reason for the failure was the large variation in results. The likely cause was the lack of availability of 13C isotope internal standards for these PAHs at the time of the study. The protocol has been shown to be fit-for-purpose and is suitable for formal validation by inter-laboratory collaborative study.
灰米奇 2010/02/04
可以到文献求助版面来求助 http://bbs.instrument.com.cn/forum_522.htm 权限不够,帮你补两个链接: 1. http://www.informaworld.com/smpp/content~db=all?content=10.1080/02652030601135936 2. http://chinesesites.library.ingentaconnect.com/content/tandf/tfac/2007/00000024/00000006/art00010;jsessionid=2a3aw5ctdglw5.victoria
  • 灰米奇
    第1楼2010/02/04
    可以到文献求助版面来求助
    权限不够,帮你补两个链接:
    1.
    2.
  • siemens00
    第2楼2010/02/04
    谢谢!我是新手,还不知道有文献求助版:(
    灰太狼(eginzon) 发表:可以到文献求助版面来求助
    权限不够,帮你补两个链接:
    1.
    2.
