polymer
第1楼2010/02/10
只从语法角度说,完全同意你的意见,是前者。
如果是后者,absolute应修饰mv value 而不是 mv difference. Calculate the difference of absolute mv between the two buffers.
影子
第3楼2010/02/10
我也理解为是前者。如果要用英文表达后者,可不可以这样写:
Calculate the absolute mV differnece for replicate determinations of the two buffers,respecitively.
ja19840616
第9楼2010/12/27
Calculate the difference of absolute mv between the two buffers,
这句是不是有点问题? between 和 of 的位置有点不太顺口
应该是这样好点
Calculate the difference between absolute mv of the two buffers
