poorlittle
第5楼2011/03/07
Suggestion : 第467条"残余溶剂”
Is it possible that "In addition, the toxicity and residual level of each solvent shall be taken into consideration, and the solvents (shall be ???) limited according to the principles defined and the requirements specified in Residual Solvents <467>, using the general methods presented therein or other suitable methods."
If it is read as “the solvents shall be limited”, my interpretation would be :
并根据A及应用B来规限溶剂.
Where
A = [(the principles defined) and (the requirements specified)] in Residual Solvents <467>
B = the general methods presented therein or other suitable methods
sjbsjbsjb
第7楼2011/03/11
您的解答方式很得体,受教了。
