dong3626 2010/03/10
1.[b][color=#ff0000]Effect of retained austenite stability on mechanical properties of 590MPa grade TRIP sheet steels[/color][/b] [b][color=#ff0000][/color][/b] [b][color=#ff0000]1和3重复[/color][/b]
灰米奇 2010/03/09
[color=#fd1289][size=4]楼主应该先看一下版规,现在一帖最多只能求助5篇文献。[/size][/color]
怪味陈皮
第1楼2010/03/09
【序号】: 4
【作者】: Jeong, W.C. ; Matlock, D.K.; Krauss, G.
【题名】: Observation of deformation and transformation behavior of retained austenite in a 0.14C-1.2Si-1.5Mn steel with ferrite-bainite-austenite structure
【期刊】: Materials Science and Engineering A
【年、卷、期、起止页码】: v A165, n 1, p 1-8, Jun 25 1993
【全文链接】: http://www.sciencedirect.com
【序号】: 5
【作者】: Vasilakos, Apostolos N. ; Papamantellos, Kostas; Haidemenopoulos, Gregory N.; Bleck, Wolfgang
【题名】: Experimental determination of the stability of retained austenite in low alloy TRIP steels
【期刊】: Steel Research
【年、卷、期、起止页码】: v 70, n 11, p 466-471, November 1999
【全文链接】: http://cat.inist.fr/?aModele=afficheN&cpsidt=1243582
