请问我打开OMNIC软件,出现个对话框说A configuration file is required to use this application。 Plesase use open configuration in the file menu to open a configuration file 。我按他说的做以后,查找类型是Configurations(*.CON)时查找范围内没有文件,文件类型是All files 时,有omnic 文件了 ,可是打不开。谁知道应该怎么弄啊。 谢谢,很急!!
A file that you can open to set up the menus, the toolbar and software options for the way you prefer to use OMNIC. You can customize OMNIC and save your settings in an configuration file to be opened later。 文件/打开配置
