何当奇
第1楼2010/03/24
A minor decrease in the mass gain was observed as the temperature was increased to 35 ℃, possibly as an effect of lower amount of cuprite due to a thinner adlayer on the metal surface at 35 ℃.
当温度升至35 ℃时,增重有所减少,也许是35 ℃时金属表面鹰岩层导致较低量赤铜矿的影响。
如与从一个理想的吸收剂(0.19±0.02 cm/s.)相比,铜上 HNO3的在65% RH, 25 ℃ and 0.03 cm/s 空气速率时的沉积速率高达0.15±0.03 cm/s。
zting86919
第2楼2010/03/24
Thanks~还想问一下,那个鹰岩层是什么?我一直查不到a thinner adlayer 的意思,这个就是鹰岩层?再次感谢~
poorlittle
第7楼2010/03/25
From http://en.wiktionary.org/wiki/adlayer, adlayer is “Blend of adsorb and layer” and its definition is “(chemistry) An adsorbed layer; in surface chemistry, a layer that is chemically interacting with the substrate.”
The Chinese translation of adlayer could not be found from Google, but when searching with the keywords “adsorption layer”in CNKI ( http://dict.cnki.net/dict_result.aspx?searchword=adsorption%20layer ), the following Chinese terms were found:
· 吸附层(42)
· 吸收层(0)
· 吸附层厚度(12)
· 吸附层的(9)
· 吸附面(1)
天晴了
第10楼2010/03/26
原句1: A minor decrease in the mass gain was observed as the temperature was increased to 35 ℃, possibly as an effect of lower amount of cuprite due to a thinner adlayer on the metal surface at 35 ℃.
随着温度升到35℃,直线斜率略有降低,可能是金属表层在35℃时吸附层变薄,铜的数量减少引起的。
原句2:The Vd of HNO3 on copper at 65% RH, 25 ℃ and 0.03 cm/s air velocity was as high as 0.15±0.03 cm/s, to be compared with the value obtained for an ideal absorbent, 0.19±0.02 cm/s.(Vd为硝酸在金属铜表面的沉积速率)
65% RH, 25 ℃,空气速率为0.15±0.03 cm/s时硝酸在金属铜表面的沉积速率高达0.15±0.03 cm/s,与之相比,理想吸附剂的数值为0.19±0.02 cm/s。
