【数据内容】 The Aldrich Spectral Viewer is an electronic referencebook on CD-ROM that contains thousands of actual spectra from the Aldrichspectral libraries. This program is more powerful than a printed book, allowing text and data fieldsearching and the manipulation, printing, and exporting of spectra.
Currently, one FT-IR library (over 11,000compounds) and two FT-NMR libraries (over 15,000 compounds) are offered. Thelibraries can be used individually or can be combined. A single user interfacehandles both IR and NMR spectra, simplifying the use of the software. Inaddition, the Spectral Viewer is expandable so that when new spectral librariesare released, they can be easily added to the software.
