不太明白红狐的意思?下面是USP通则上的部分内容,不知有没有用?
<921> WATER DETERMINATION
Many Pharmacopeial articles either are hydrates or contain water in adsorbed form. As a result, the determination of the water content is important in demonstrating compliance with the Pharmacopeial standards. Generally one of the methods given below is called for in the individual monograph, depending upon the nature of the article. In rare cases, a choice is allowed between two methods. When the article contains water of hydration, the Method I (Titrimetric), the Method II (Azeotropic), or the Method III (Gravimetric) is employed, as directed in the individual monograph, and the requirement is given under the heading Water. The heading Loss on drying (see Loss on Drying <731>) is used in those cases where the loss sustained on heating may be not entirely water. <731> LOSS ON DRYING
The procedure set forth in this chapter determines the amount of volatile matter of any kind that is driven off under the conditions specified. For substances appearing to contain water as the only volatile constituent, the procedure given in the chapter, Water Determination <921>, is appropriate, and is specified in the individual monograph.
