poorlittle
第2楼2010/06/10
同感。 以上资料我十年前已看过, 现在重新再学一遍, 又有新体会。
Why the concept of Exact Value and Inexact Value is important? Here is my experience:
I know that the average of 0.13, 0.25, 0.19, 0.32,0.41 is
(0.13+0.25+0.19+0.32+0.41)/5=0.26
I would not report that the average = 0.3 by taking into account of the number of significant figure of 5 (i.e. n.s.f.=1 for the number 5), but I did not know the reason in the past. Now, I know that 5 is an exact value, so the rules of arithmetic operation for significant figures do not apply.
(There is another opinion that although 5 is an exact value, if the concept of significant figure must be imposed on it, 5 has infinite number of significant figures, i.e. 5=5.0000……00000)
I am thinking whether the limiting value (极限值, 或称界限值) specified in the testing standard is an exact value. If it is an exact value, I need not consider the number of significant values when I report the measured value, only consider the precision as indicated by the limiting value.
例: 极限值=0.030%, 测定值=0.1573%
My opinion:
(1) 我不认为0.030%是一个有2位有效数字的数, because it is an exact value
(2) 0.030%显示了精度要求为千分位
Therefore:
(A) 我不会报0.16%, 這会損失精度, 亦与有效数字的概念无关(see (1) above)。
(B) 我也不会报0.1573%, 这会太长而无助于判定是否合格
我会报0.157%
poorlittle
第4楼2010/06/12
Inexact value ≠ significant figure, I think that significant figure is one of the attributes of inexact value. I am still studying this subject and unable make the precise definitions for them. Perhaps, the following example may illustrate their difference:
If the population of a city is 1.030×106 in government survey record and when it is printed as 1030000 in the newspaper, I would have the following description about the value 1030000:
1030000 is an inexact value (人口统计时是以千为单位的, 不会精确至几百几十的)
1030000 是一个7位数
1030000 具有4位有效数字
1030000中 1,0,3,0 是有效数字, 最右的三个0是定位0
我似乎在鑽牛角尖, 但我的工作之一是计量, 对一些有关数字的基本概念不能不理啊。
poorlittle
第7楼2010/06/24
“标准多少有效数字就多少位数”?
The problem is how do you interpret “位”. In the past month, I studied the “significant figure” again and found that there are two meanings of “位”, i.e. “number” and “place”. Example:
(A) 0.00235 : 3位有效数字 (number of significant figures = 3)
(B) 0.00235 : 精确至小数後5位 (5 decimal places)
http://bbs.instrument.com.cn/shtml/20100608/2599734/ 中提到 “药典明确规定了结果的有效位数要和标准一致啊!!”, 这个“位数要和标准一致”中的“位数”应是(B)“place”. If this interpretation is accepted, there is no difference between 国标 and 国外某企业的SOP. (GB/T 8170-2008 Clause 4.3.3.1中用的字是“数位”一致, my interpretation is “in agreement with the places of the limiting value”)
I am writing a notes about the Significant Figure, and really really want to know the exact wording in 中国药典
My suggestion to your SOP about rounding is “the rounding of the measured value should be in agreement with the limiting value” 轻轻带过, 留有演译的余地;
or more specific “the rounding of the measured value should be in agreement with the places of the limiting value” so as to be in line with GB/T 8170-2008 Clause 4.3.3.1
or “in accordance with xxxxxx unless otherwise specified”
happy王子矜
第8楼2010/06/24
恩,谢谢微寒老师的建议。其实我现在面对的与其说是数字的修约问题,不如说是数据报告习惯的问题。除了对外的药品企业外,我看到的一般情况就是,仪器检测出多少数据就是多少。比如,一个液相检测杂质报告0.0005%,实际情况是,这个仪器或方法根本没有这样的检出限,但是如果你报告<0.01%(假设检出限是0.01%),领导就不认可。非得让你写个确切的数字。
我们现在的规定是:按照有效数字的位数,检测标准有多少位,结果就报告多少位,如果有100%或0的情况,就往下多保留一位,直至不为100%或0为止.没提检出限这回事。
另:微寒老师的论坛内另外个帖子的链接,我的google浏览器打开后,每次点关闭这个页面,浏览器就崩溃一次。
poorlittle
第9楼2010/06/24
A quantitative result sometimes or to some extent would become a qualitative indication.
领导要照顾一些非专业客户(或专业客户的非专业领导), 让报告填上数字, 令报告看起来有根有据, 亦无可厚非。 行内人会明白, any value below the detection limit is only an indication. An indication of 非常非常少的杂质。
( “飞流直下三千尺”, 这个三千不是真的quantitative value of 3000, but a qualitative indication of 高。 所以, 能科学地出一份报告固然好, 若要报一个小于检出限的数值作为indication, 也不是不能自园其说的。)
