仙豆
第1楼2010/07/01
Standard Test Methods for
Flexural Properties of Unreinforced and Reinforced Plastics
and Electrical Insulating Materials1
This standard is issued under the fixed designation D790; the number immediately following the designation indicates the year of
original adoption or, in the case of revision, the year of last revision. A number in parentheses indicates the year of last reapproval. A
superscript epsilon (´) indicates an editorial change since the last revision or reapproval.
