【求助】IntensityMatrix Object 原理
  • suiyixiaozhai
    2010/08/16
专业英语
  • 在学习pyms,在user guide中看到此处,被卡住了,实在不知道是什么意思?希望高手能帮帮忙???
    The general scheme for converting raw mass values is to bin intensity values based on
    the interval the corresponding mass belongs to. The general procedure is as follows:
    • Set the interval between bins, lower and upper bin boundaries
    • Calculate the number of bins to cover the range of all masses.
    • Centre the first bin at the minimum mass found for all the raw data.
    • Sum intensities whose masses are in a given bin.
    A mass, m, is considered to belong to a bin when c − l ≤ m < c + u , where c is the
    centre of the bin, l is the lower boundary and u is the upper boundary of the bin.
    The default bin interval is one with a lower and upper boundary of ±0.5.
    A function to bin masses to the nearest integer is also available. The default bin
    interval is one with a lower boundary of -0.3 and upper boundary of +0.7 (as per
    the NIST library).
    英文原文如上,尤其是
    这四步,看不明白。
  • symmacros
    第2楼2011/08/31
    PYMS是热解质谱法吗?
