I was told, that the certificate we need should be EP 6.
EP 6.1 in only reference to the fact that the production and quality is in accordance with the EP 6 requirement.
EP 6. means that the product and production is under continious development.
Our authorities do accept EP6, but unfortunatelly EP6.1 is not acceptable.
Is there a way to get Marbofloxacin with EP6 certification. Most likely you this as well if you have DMF open and closed part. 我就不明白了,EP6.1应该是EP6的一个增补版吧,为什么不能写EP6.1,非得写EP6呢? 麻烦各位指点一下。
