不知道错误代码 参考: Plunger not in home position or not operating properly • Plunger not completely in home position. ↓ Press the RESET key. • Plunger does not move smoothly. See Note 1. ↓ Turn the power off, remove the syringe and rinse the plunger.
kila(kila)发表:不知道错误代码 参考: Plunger not in home position or not operating properly • Plunger not completely in home position. ↓ Press the RESET key. • Plunger does not move smoothly. See Note 1. ↓ Turn the power off, remove the syringe and rinse the plunger.
