自制吸附萃取搅拌棒结合气相色谱嗅觉计(GC/O)、气质联用仪(GC/MS)分析肉味香精呈香组分
The identification of volatile meat flavor components using SBSE made by ourselves, GC/O and GC/MS
摘要:采用自制吸附萃取搅拌棒对肉味香精呈香组分进行提取,利用热脱附仪进样,结合气相色谱嗅觉计联用(GC/O)、气质联用(GC/MS)双重定性方式,令组分富集率更高,检测结果更加真实、客观地反映出香精的香气组成。为高级香精的调配及仿香工作提供有力依据。实验仪器采用在色谱柱出口安装“石英三通”进行1:1分流,样品被同时引入质谱和嗅觉计,避免了单一定性方法存在的不足。其中,两种方法共同检出的物质31种,仅GC/O检出的物质24种,仅GC/MS检出的物质26种。
关键词:搅拌棒吸附萃取(SBSE),热脱附仪(TD),气相色谱嗅觉计联用(GC/O);气质联用(GC/MS);肉味香精;呈香组分
Abstract: Extracting meat flavor aroma components with stir bar sorptive extraction (SBSE)made by ourselves, introducing sample by thermal desorber(TD) and identifying by the cooperation of gas chromatography /olfactory(GC/O) and gas chromatography/mass spectrometry (GC/MS), we got the qualitative results that reflected more truely and objectively the composition of flavor. It provided powerful data support to blend and copy of advanced flavor. Quartz three-way pipe was installed at the exit of column to bring sample(1:1) to spectrometry and olfactory at the same time, which avoided the disadvantage of using only one analytical method . Among them, We can detect 31 compounds by both GC/O and GC/MS, 24 only by GC/O and 26 only by GC/MS.
Key words: Stir Bar Sorptive Extraction (SBSE); Thermal Desorber(TD); Gas Chromatography /Olfactory (GC/O); Gas Chromatography/Mass Spectrometry (GC/MS);Meat Flavor; Aroma Component
