symmacros
第1楼2010/12/10
帮楼主贴出了:
Name: 1,2-Benzenedicarboxylic acid, mono(2-ethylhexyl) ester
Formula: C16H22O4
MW: 278 CAS#: 4376-20-9 NIST#: 291384 ID#: 110647 DB: mainlib
Other DBs: RTECS, EINECS
Contributor: NIST Mass Spectrometry Data Center, 1998.
10 largest peaks:
149 999 | 167 318 | 57 293 | 71 173 | 43 165 |
70 154 | 41 140 | 150 116 | 55 115 | 113 94 |
Synonyms:
1.Mono(2-ethylhexyl) phthalate
2.Phthalic acid, mono-(2-ethylhexyl) ester
3.Mehp
4.Monoethylhexyl phthalate
5.Mono-2-ethylhexyl phthalate
6.2-([(2-Ethylhexyl)oxy]carbonyl)benzoic acid #
Estimated non-polar retention index (n-alkane scale):
Value: 2162 iu
Confidence interval (Diverse functional groups): 89(50%) 382(95%) iu
Retention index.
1. Value: 2555.3 iu
Column Type: Capillary
Column Class: Semi-standard non-polar
Active Phase: HP-5MS
Column Length: 30 m
Carrier Gas: He
Column Diameter: 0.25 mm
Phase Thickness: 0.25 um
Data Type: Linear RI
Program Type: Ramp
Start T: 80 C
End T: 300 C
Heat Rate: 4 K/min
Source: Zeng, Y.-X.; Zhao, C.-X.; Liang, Y.-Z.; Yang, H.; Fang, H.-Z.; Yi, L.-Z.; Zeng, Z.-D., Comparative analysis of volatile components from Clematis species growing in China, Anal. Chim. Acta., 595, 2007, 328-339.
2. Value: 2549.5 iu
Column Length: 30 m
Carrier Gas: He
Program Type: Ramp
Start T: 80 C
End T: 300 C
Heat Rate: 4 K/min
Source: Zhao C.X.; Li, X.N.; Liang Y.Z.; Fang H.Z.; Huang L.F.; Guo F.Q., Comparative analysis of chemical components of essential oils from different samples of Rhododendron with the help of chemometrics methods, Chemom. Intell. Lab. Syst., 82, 2006, 218-228.
