【序号】:1 【作者】:P. Pandit and S. Basu 【题名】:Dye and Solvent Recovery in Solvent Extraction Using Reverse Micelles for the Removal of Ionic Dyes 【期刊】:Ind. Eng. Chem. Res., 【年、卷、期、起止页码】:2004, 43 (24), pp 7861–7864 【衔接】:http://pubs.acs.org/doi/abs/10.1021/ie0402160
【序号】:2 【作者】:P. Pandit and S. Basu 【题名】:Removal of ionic dyes from water by solvent extraction using reverse micelles 【期刊】:Environ. Sci. Technol., 【年、卷、期、起止页码】:2004, 38 (8), pp 2435–2442 【衔接】:http://pubs.acs.org/doi/abs/10.1021/es030573m
