【分享】LC/MS检测人体血浆中的磷霉素 英文文献
厂商论坛
  • Abstract
    A rapid and selective liquid chromatographic/tandem mass spectrometric method for determination of fosfomycin was developed and validated. Following protein-precipitation, the analyte and internal standard (fudosteine) were separated from human plasma using an inocra-
    tic mobile phase on an UltimateTM XB-CN column. An API 4000 tandem mass spectrometer equipped with Turbo IonSpray ionization source was used as detector and was operated in the negative ion mode. Multiple reaction monitoring using the precursor to product ion combinatio-
    ns of m/z 13779 and m/z 17891 was performed to quantify fosfomycin and fudosteine, respectively. The method was linear in the conce-
    ntration range of 0.10–12.0μg/mL using 50μL of plasma. The lower limit of quantification was 0.10μg/mL. The intra- and inter-day relat-
    ive standard deviation over the entire concentration range was less than 10.6%. Accuracy determined at three concentrations (0.25, 1.00 and 8.00μg/mL for fosfomycin) ranged from 1.0% to 4.2% in terms of relative error. Each plasma sample was chromatographed within 5.0 min. The method was successfully used in a bioequivalence study of fosfomycin in human plasma after an oral administration of capsules containing 1.0 g fosfomycin (1.3 g calcium fosfomycin).
    © 2007 Elsevier B.V. All rights reserved.
    Keywords: Liquid chromatographic/tandem mass spectrometry; Fosfomycin; Plasma concentration
  • 阿三
    第1楼2011/03/01
    代谢的文章,学习了
  • iamquan
    第2楼2011/03/20
    英文啊,看起来有点眼花
  • naruto1988
    第3楼2011/04/27
    色谱B的文献?还不错
  • naruto1988
    第4楼2011/04/27
    一般来说只有英文的文献才具有一定的可信度至于中文很多都是瞎搞的
    iamquan(iamquan) 发表:英文啊,看起来有点眼花
  • 999youran
    第5楼2014/06/27
    来电中文对照就更好了
