毛细管电泳(CE)
poplar_yang
第1楼2011/03/31
release timing need calculations, v.s. the reagent peak, v.s. the water peakthen you can identify peak with electronegativity EN, those chemicals coming out one by one based on electronegativity,
april110016
第2楼2011/04/01
把对照品加到样品里,哪个峰增大,基本就是他了,还有,对照品都分不开,样品怎么能分得开呢,,或者弄得清谁是谁呢?再摸摸条件吧
