1. When a specified concentration is called for in a procedure, a solution of other normality or molarity may be used, provided that allowance is made for the difference in concentration and that the change does not increase the error of measurement.
2. Unless otherwise indicated, analyte concentrations shall be prepared to within ten percent (10%) of the indicated value.
