yxcxzqx
第4楼2006/01/17
Laboratory Accreditation Bureau (L-A-B) (Website:www.l-a-b.com)发布的
Guidance for Documenting and Implementing ISO/IEC 17025:2005 &
Laboratory Guidance (Revision Original — 09/07/05)
"When the investigation proves that a non-conformance exists, the procedure should lead into the formal corrective action procedure as defined in clause 4.11. The procedure shall also define the process by which the laboratory will process the non-conforming work, whether it is acceptable or the test/calibration will need to be repeated, etc."
因而,本人坚持自已的观点:。“可接受性”意指不影响最终检测结果(尽管有不符合因素)。
