symmacros
第7楼2011/05/26
Amdis里有peak tailing, 可以参考。
(Peak Tailing: The ratio of the area to the right (later time) of the center of the peak to area to on the left of the peak (earlier time). A well-formed peak has a value near one. Excessive tailing will yield values much greater than 1.)
